Subject: Wall materials
Sheedee opened this issue on Jul 19, 2012 · 8 posts
Sheedee posted Thu, 19 July 2012 at 1:08 PM
Hello;
Can some one please tell me where i can find shiny materials to apply to walls...like shiny tiles and stuff like that?...or if there is a room prop any where with shiny walls?...
Thanks.
PS. i use Poserpro 2012
ghostman posted Thu, 19 July 2012 at 1:23 PM
Comes with the program. In the prop folder you have walls to build a room and in the material folder you have materials for it.
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
SamTherapy posted Thu, 19 July 2012 at 1:30 PM
Use the Tile node on the One Sided Square.  Play with the tile sizes, colours and so forth to get the result you want.
vilters posted Thu, 19 July 2012 at 1:37 PM
Specular will bring you shine.
Blinn will bring you shine
Glossy will bring you shine.
A bump/displacement map, the tile node, and yes the brick node give you all what you can dream off for a wall.
Sheedee posted Thu, 19 July 2012 at 2:37 PM
Sorry to be such a bother people, i loaded the one sided square...but where can i access its nodes?...like the tile node for example...i went to the material room and then in the tab advanced, but i cant see the nodes.
thanks.
SamTherapy posted Thu, 19 July 2012 at 2:48 PM
You have to connect something to the One Sided Square.  Click on the little Socket thing at the side of Diffuse_Color, hold the mouse button and drag it out.  You'll see a cable and a popup.  Select Tile from the popup list.
You'll then have a node to work on.  You can change the tile colours, sizes and various other properties.
You can add a black and white version to the Bump or Displacement channels, and maybe play around with Alternate_Specular to give your tiles a glossy look.
Addendum:  You should always use Advanced mode in the Material Room.  The other is for numpties.
vilters posted Thu, 19 July 2012 at 2:54 PM
Click on the small loudspeaker that is behind all options in the left colon. Drag to the right A menu opens See screengrab.
Read the manual for what does what and goes where.
oesp, X-posted with Sam
Please Shedee, reduce font size?
Thanks, makes it hard to read this way.
