Subject: No Hair to be seen
mdbruffy opened this issue on Jul 21, 2012 · 30 posts
mdbruffy posted Sat, 21 July 2012 at 8:26 PM
I have a story in the works that calls for an older character- one closer to 60 than 30. Yet, we seem to be,living in the world of "Logan's Run" where nothing is for anyone over 28. Can some one help me out here?
Gremalkyn posted Sat, 21 July 2012 at 8:44 PM
Marketplace:  "Older"
http://www.renderosity.com/mod/bcs/search.php?adv_search=&criteria=older&dept=&type=B
Marketplace:  "Old"  Some are building, but at least 6 people on page 1 (did not look at the other pages)
http://www.renderosity.com/mod/bcs/search.php?adv_search=&criteria=old+&dept=&type=B
(Curiously, Marketplace: Senior only lists hot teen girls.)
Will look in Free Stuff next
Gremalkyn posted Sat, 21 July 2012 at 8:46 PM
Free Stuff: "old" only had this for people:
http://www.renderosity.com/mod/freestuff/details.php?item_id=60285
Free Stuff:  "elderly"
http://www.renderosity.com/mod/freestuff/search.php?section_id=-1&query=elderly&sort=relevancy&use_age=no&older_age=&older_units=day&newer_age=&newer_units=day&username=&section_selector%5B0%5D=-1
Free Stuff:  "senior" had this old lady (and some teens):
http://www.renderosity.com/mod/freestuff/details.php?item_id=63531
mdbruffy posted Sat, 21 July 2012 at 8:50 PM
Quote - Marketplace:  "Older"
I'm looking for Hair simular to the picture I posted.. not morphs.
Gremalkyn posted Sat, 21 July 2012 at 8:56 PM
Oh.
This come close:
http://www.renderosity.com/mod/bcs/combed-over-hair-for-mike-3/22997
Will look some more before I have to log.
moriador posted Sat, 21 July 2012 at 9:00 PM
There are quite a few character/texture sets for the over 30s, but hair is definitely lacking.
Products for males don't sell as well as those for females.  Thinning hair for balding men is going to sell even less well. So no surprise there's almost none of it.
Some hair sets do have morphs that adjust the hairline and/or give a widows peak and grey/white textures are becoming more popular, but these things aren't usually emphasized in the promos.
If I get a chance, I'll have to look through my library and see if anything I have even comes close.
Gremalkyn posted Sat, 21 July 2012 at 9:07 PM
No idea what version of Poser the OP is using, but my P7 has:
Poser 1 - 5 --> Hair --> Poser 4 Hair --> Male Hair 2
Not as severe a loss as poor Uncle Walter but close and can be tinted however you want.  Can be used as a prop on other figures if you load it without a person, then save it as a prop.
mdbruffy posted Sat, 21 July 2012 at 9:10 PM
Quote - There are quite a few character/texture sets for the over 30s, but hair is definitely lacking.
Thanks. I'll be watching for your post.
Gremalkyn posted Sat, 21 July 2012 at 9:13 PM
No idea if this would help:
http://www.renderosity.com/mod/bcs/mature-hair-resource/43406
mdbruffy posted Sat, 21 July 2012 at 9:15 PM
Quote - No idea what version of Poser the OP is using, but my P7 has:
I'm using Poser 9- but my Runtime dates back to P5- which included the P4 hair. I have the Male Hair 2 prop. I'll save it as a last resort. It would need a much better texture map.
mdbruffy posted Sat, 21 July 2012 at 9:16 PM
Quote - No idea if this would help:
That's just for making textures- not the hair itself.
Glitterati3D posted Sat, 21 July 2012 at 10:38 PM
Here ya go, a freebie from AprilYSH:
http://shop.aprilsvanity.com/cat_10.html
Scroll down to Mitch Hair
Believable3D posted Sat, 21 July 2012 at 10:44 PM
I think I'd just use the hair room.
______________
Hardware: AMD Ryzen 9 3900X/MSI MAG570 Tomahawk X570/Zotac Geforce GTX 1650 Super 4GB/32GB OLOy RAM
Software: Windows 10 Professional/Poser Pro 11/Photoshop/Postworkshop 3
aRtBee posted Sun, 22 July 2012 at 2:09 AM
I did some hair room tuts on my Missing Manuals website, perhaps these may help.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
moriador posted Sun, 22 July 2012 at 4:36 AM
Alexios Hair, adjusted with some extreme dial spins.
Well, I played around with quite a few short hair styles. Most have a few adjustments, but none of them really adjusts very much.
The best one I found in my runtime was Alexios Hair (at Daz).  Dial spinning will only get you so far, however.  I found I had to use the morph brush to drag the hairline and flatten the hair. Fortunately, this particular hair isn't terribly difficult to morph with the brush (I spent about 5 minutes on it, and I'm hardly an expert). I also had to lighten the hair materials. The image files would probably need to be adjusted in a 2d editor to get a truly white head of hair.
So, yeah, straight out of the box, there's not much available. Some fiddling (20 minutes or so?) required.
moriador posted Sun, 22 July 2012 at 4:37 AM
Alexios Hair with dial spins, some morph brush work, and lighter materials.
mdbruffy posted Sun, 22 July 2012 at 4:40 AM
Quote - I think I'd just use the hair room.
I have never used the hair room in my life- and I've been a Poser user since P5. It's always seemed way too involved.
mdbruffy posted Sun, 22 July 2012 at 4:41 AM
Someone recommended the Mature Mark Hair. I'm going to take a look at it and see what kind of morphs it has.
moriador posted Sun, 22 July 2012 at 4:45 AM
Mature Mark Hair with dial spins only.
Quote - > Quote -  Alexios Hair with dial spins, some morph brush work, and lighter materials.
This was the best I could do. My morph brushing did not look good with this one, so this is just dial spinning.
Its hairline morph isn't very strong, so I had to fiddle a lot with the dials to get it to actually move much.  You might get better results.
For whatever reason, it's not as amenable to the morph brush, in my opinion.
MistyLaraCarrara posted Sun, 22 July 2012 at 8:12 AM
the glynn hair comes with a gray texture.  it's my favorite for frumpy-ish older gents.
MistyLaraCarrara posted Sun, 22 July 2012 at 8:15 AM
Quote - snip
lol, maybe it's picking up on high school senior?
Acadia posted Sun, 22 July 2012 at 10:11 AM
I've been asking for hair for older people for years. No one seems to want to make any.
As people age, even women, their hair becomes thinner and more sparse.
The existing hairs that I've found around Poserdom are not realistic as to the type of hair an older person would have. Yes, you can change the texture to a grey, white or salt/pepper, but the fact that they are so "full" and "lush", really doesn't lend itself to what is typical of the average older person.
Believable3D posted Sun, 22 July 2012 at 10:12 AM
mdbruffy, the Hair Room is pretty involved... for long hair. For short hair, relatively simple.
As for the others... you may have to use a transparency map to get the receding hairline you want, but it won't necessarily work very well with every model.
______________
mdbruffy posted Sun, 22 July 2012 at 11:07 AM
Checking in over lunch.
 Acadia, I understand exactly what you're saying. That's why I said it feels like a"Logan's Run" world. In that movie, no one was allowed to live past the age of 30.
believable 3d, I understand what you're saying about transparency maps. Some m odels are alot harder to fit than others.
bopperthijs posted Sun, 22 July 2012 at 3:45 PM
DAZ has an elderlies set for M3 for some years.
I find the characters rather creepy, but the textures are great, and with some additional morphing you can make a nice grandpa out of them.
Here's the link:
http://www.daz3d.com/shop/the-elderlies/
regards,
Bopper.
-How can you improve things when you don't make mistakes?
mdbruffy posted Sun, 22 July 2012 at 3:53 PM
Quote - DAZ has an elderlies set for M3 for some years.
Here's the link:
regards,
Bopper.
I'm looking for hair  like in my post at the top of this forum. not morphs.
bopperthijs posted Sun, 22 July 2012 at 4:17 PM
Sorry, but I was more referring to the textures. I know it's no real hair, but it's quite realistic for non-close-up renders.
BTW This hair form DAZ has bald hair-morph:
http://www.daz3d.com/shop/joeyducky-hairstyle/
I have used it for a selfportrait. 😄
I'm not very old, but I've been bald since I was 30.
moriador posted Sun, 22 July 2012 at 5:38 PM
Quote - BTW This hair form DAZ has bald hair-morph:
Ah, dunno about the OP, but this is the sort of thing I would be looking for, depending on how versatile the hairline morph is...
Thanks
mdbruffy posted Sun, 22 July 2012 at 9:11 PM
Okay, decided to go with Mature Mark Hair from Daz with the morphs pushed to their limits. The  character's not as exact as I wanted, but I think he's as good as I can make him.
mdbruffy posted Sat, 28 July 2012 at 8:10 PM
Okay, new search. Anyone know where I can find a hair model even remotely simular to this? I really need it.
