Marque opened this issue on Jul 29, 2012 · 6 posts
Marque posted Sun, 29 July 2012 at 9:22 AM
I was told by someone in the Daz forums that Animate 2 does not work with Genesis, can someone tell me if this is true before I buy it?
Thanks
RHaseltine posted Sun, 29 July 2012 at 3:28 PM
You should be able to test using the Lite version in DS - I think, however, that it's not a question of the plugin's not working, but rather than most AniBlocks are made for V4/M4 and as a result may not work perfectly with Genesis (particularly the feet).
ProPose001 posted Sun, 29 July 2012 at 3:54 PM
Quote - You should be able to test using the Lite version in DS - I think, however, that it's not a question of the plugin's not working, but rather than most AniBlocks are made for V4/M4 and as a result may not work perfectly with Genesis (particularly the feet).
is there a quick fix available for the feet issue
RHaseltine posted Mon, 30 July 2012 at 9:06 AM
I can't recall - this was discussed recently, either here or on the DAZ forums, and I think the solution was a new aniblock that corrected the foot rotations. However, I don't have a link and it may have been a suggestion of something that could be done rather than a link to something that was available.
Marque posted Mon, 30 July 2012 at 9:15 AM
Thank you for your help. May just wait to see if it goes on sale again.
KristiS posted Mon, 30 July 2012 at 2:01 PM
Hello,
If you contact the vendor of the product, I am sure they will tell you so you will know before you buy it :)
Kristi
Community Relations Specialist
This is your life - your platform - your stage - your story
