Darkworld opened this issue on Jul 31, 2012 · 4 posts
Darkworld posted Tue, 31 July 2012 at 3:09 PM
Using Poser Pro 2012, need to parent the lights to the Main Camera, so that I can rotate to any angle without wrecking the lighting. Anyone know a way to do this?
Thanks!
3doutlaw posted Tue, 31 July 2012 at 3:13 PM
Assuming you've tried and failed :)
How about make a prop, and parent the lights and camera to that prop?
...or
Just parent lights to a prop, and move prop, keeping same camera angle, which will give various angle of a good lighting rig?
cspear posted Tue, 31 July 2012 at 3:22 PM
Point and spot lights you should be able to parent without problem. For infinite lights, change them to spots, parent to the camera, then change back to infinite.
PoserPro 11 - Units: Metres
Adobe CC 2017
Darkworld posted Wed, 01 August 2012 at 11:06 AM
Quote - Point and spot lights you should be able to parent without problem. For infinite lights, change them to spots, parent to the camera, then change back to infinite.
worked beautifully. thanks!
