Subject: CR Pro II or Another Utility
thebert opened this issue on Aug 11, 2012 · 6 posts
thebert posted Sat, 11 August 2012 at 12:03 PM
I've been run Cr Pro II for years now and today it stopped working. I'm running windows 7 Home premium and Poser Pro 2012.  I see it not been updated in years also. So is there another utility program or scripts that does the same thing.  I like installing to a install folder and checking the new product out before moving it to my working folders. I can also move thing around like injection morphs to a morphs folder.  Cr Pro II did a very nice job and let me fix any little issues.
Any Help?
Thanks
thebert
The difference between stupidity and genius is that genius has its limits.
Eric Walters posted Sat, 11 August 2012 at 2:12 PM
Not sure what Cr Pro is-but it may have to do with it's version of Python. There is a thread on Runtime DNA about scripts that have been updated to work with PoserPro2012. If you have Pro2010 you might see if you can make your changes within Pro2010-then continue with Pro2012. There was a free Python script that unhid hidden parameters that worked in Pro2010 but not Pro2012- so I moved the eyes inwards using the script in 2010-then rendered in 2012.
Eric
thebert posted Sat, 11 August 2012 at 2:36 PM
Cr pro II in a utility at checks the poser files for errors, Like missing textures or miss Named textures or obj.  I've not found one at RDNA or here, I'm hoping  someone can tell me of one
Thanks
3anson posted Sat, 11 August 2012 at 2:39 PM
RuntimeRepair, by D3D can do that, i believe
Snarlygribbly posted Sat, 11 August 2012 at 4:56 PM
I use CR Pro II.
It's still running fine for me on Windows 7 64bit and Poser Pro 2012
Make sure you have the latest updates because without them CR Pro II would fail when its database become very large.
My version is 2.1.1.23
Free stuff @ https://poser.cobrablade.net/
PhilC posted Sun, 12 August 2012 at 3:49 PM
Checking the resources found in a Poser file is just one of the many tasks made simple by the PZ3 Editor.
http://www.philc.net/PZ3editor.php
