fmfdoc opened this issue on Aug 14, 2012 · 10 posts
fmfdoc posted Tue, 14 August 2012 at 10:30 PM
Not sure what happenned but all the figures like Milkmanandy, jesse, etc are gone after i ran the sr3 update. Also the default ground.obj. Did anyone else have this happen?
Hana-Hanabi posted Tue, 14 August 2012 at 10:37 PM
How odd. Mine didn't even overwright my mainButtons.py. >_>
花 | 美 | 花美 | 花火
...It's a pun.
fmfdoc posted Tue, 14 August 2012 at 10:39 PM
I know, I can't figure it out. All the daz characters are still in library. I even checked the hard drive and they are all gone. Poser Pro 2012, and had the SR2 update installed all ready. I will have to wait till I get home and reinstall then try again to run the SR3
ssgbryan posted Tue, 14 August 2012 at 10:42 PM
I haven't.
LaurieA posted Tue, 14 August 2012 at 10:48 PM
Yeah, I still have all mine as well.
Gareee posted Tue, 14 August 2012 at 10:53 PM
Did you install it into a new location, with only the minimum installed? If so, your old installation has your complete runtime.
fmfdoc posted Tue, 14 August 2012 at 11:31 PM
Quote - Did you install it into a new location, with only the minimum installed? If so, your old installation has your complete runtime.
Mystery solved....I had installed the program to C but the content had been installed to another drive that I moved the other day. Search when run from within poser for the missing files would not find them. Copied the folder back to its original drive and all good now. Thanks for the leading me in the right direction.
Gareee posted Tue, 14 August 2012 at 11:46 PM
EricofSD posted Wed, 15 August 2012 at 1:33 AM
I suspect you didn't choose to keep your prefrences. You probably have other runtimes in your library that you need to reinstall. That happened to me.
I had runtimes from P4, PP4, P5, P6, P7, P8, PP8 and DS that I had to go find from the library and re-link. Took about a minute. Not that bad.
uli_k posted Wed, 15 August 2012 at 5:38 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3916727&ebot_calc_page#message_3916727
If you chose to back up preferences unintentionally and don't want to relink all your content runtimes, you can follow the instructions in the attached link.
