fabiana opened this issue on Aug 17, 2012 ยท 4 posts
fabiana posted Fri, 17 August 2012 at 1:36 AM
Hi I just changed my monitor today to a bigger one, and since then I have a weird occurrence.
I migrated from a 19 to a 22 inches one, LED, all nice... and all is ok but I opened Poser, with a saved scene and noticed that all the dials containing morphs have the names cutted... in some cases, are many letters making a bit annoying to see the differences on names for those morphs.
Showing here the image that shows it clear:
As is there in the image, the weird thing happens in both 64 and 32 bits versions, with all files, including V4 and the skeleton Andy... I renamed one of his dials to a longuer word, but within the normal uses for dial's names, and it cuts the last letters.
In Poser 6 and 7 that are still installed in this PC, is all good and every dial looks normal with the uncutted titles.
I noticed that the text inside PP2012 is pretty small and hard to read, specially in the material room or the parameters dials. I have did all the normal WIN things for changing text size and so but nothing seems to change the text inside Poser.
I hope somebody here can help me because I am really having a hard time with this :S
Thank you!!!
Fabi @FKDesign
One in some place under Southern Stars...
Don't tell me that I am wrong if I say I saw pointed ears this
morning, in my mirror... they are there.
Paloth posted Fri, 17 August 2012 at 3:31 AM
Maybe you could change the font size for you system globally in the Display Options if you aren't already set to "Normal", the lowest setting.
Paloth posted Fri, 17 August 2012 at 5:08 AM
fabiana posted Fri, 17 August 2012 at 10:55 AM
The font for the system is setted to be seen at 125%. I tryied putting it in things between the 100 % and the 125 % and then the cuts persist. Now setted on 125% those are gone but the text in the palettes still is too small... Is like if you have some kind of cascade style for the text sizes. The problem is that there is too much difference between the palette title and the dial's names then...
Please if someone knows how to manage this let me know, if tghere is some prog that could manage font sizes for each software independently... I have soem other progs like Cr2Editor that have too small font sizes, almost invisible in larger monitors...
Fabi @FKDesign
