Mark@poser opened this issue on Aug 28, 2012 · 6 posts
Mark@poser posted Tue, 28 August 2012 at 10:51 PM
Has anyone else noticed this? Maybe I'm just late to the dance, but I don't think I've seen a fix for this posted here.
Thanks
moriador posted Wed, 29 August 2012 at 12:18 AM
I notice it on the elbow, where the bent forearm meets the upper arm, and also the hands.
If you use EZSkin, checking BB Max Scatter Trick helps to reduce this -- the settings can be adjusted as needed.
If you don't use EZSkin, it's highly, highly recommended.
Eric Walters posted Wed, 29 August 2012 at 1:13 AM
That's a good tip Moriador. Also if you don't have the latest build-you might not have the BB Max Scatter option. SnarlyGribbly put it back in due to requests.
Quote - I notice it on the elbow, where the bent forearm meets the upper arm, and also the hands.
Snarlygribbly posted Wed, 29 August 2012 at 1:46 AM
This issue has been reported to me by several EZSkin users, most commonly because of blue ears!
And yes, this is why the Max Scatter Trick (invented by Bagginsbill) was reinstated in the latest builds.
Free stuff @ https://poser.cobrablade.net/
chris1972 posted Wed, 29 August 2012 at 2:31 AM
I noticed it on a render I did yesterday, where fingertips were touching the chest
Mark@poser posted Wed, 29 August 2012 at 7:17 AM
Quote - This issue has been reported to me by several EZSkin users, most commonly because of blue ears!
I have the latest version of your EZSKIN, and I was wondering why you had put that trick back in there. I'll give it a shot, so thanks again for your code.
Thanks everyone for the suggestions.
