Forum: Freestuff
Subject: Caprinia Pavilion- a place to relax...
McGyver13 opened this issue on Aug 31, 2012 · 9 posts
McGyver13 posted Fri, 31 August 2012 at 11:08 AM
Attached Link: Caprinia Pavilion
Caprinia Pavilion, part of the Caprinia Palace complex. The original structure was destroyed in 5532 by a massive storm that collapsed the eastern seawall causing the entire structure to be washed into the sea. An exact replica of it was constructed at the Caprinia Resorts less than a hundred kilometers from where the pavilion once stood. Caprina Pavilion was made famous as the place where Princess Arleena managed to hide from the Karellian troops who pillaged Caprinia Palace in 5389. It is rumored that the architect who designed the replica even included the underwater chamber where the Princess hid.
Tested In Poser 7 and 2010 Pro and DAZ studio 4 pro. The water shader will need tweaking in studio, but otherwise the model works fine in Studio (I actually like the way it comes out in DS4 Pro using the UberEnviroment lighting, better than Poser Pro 2010). I tested a previous version of the model in DAZ studio 2.3, so this newer version (Caprinia Pavilion) should work just fine in earlier versions of studio.
Notes:
One- The Zip file includes bump maps for many of the materials, but they are not applied… two reasons, most of my textures have some sort of fake lighting/shadow effect already in them (sorta like baked in highlights/shadows)... and I ran of time and patience with this model.
Two- I suck at making water in Poser (and DAZ)... The water is what it is and if you have suggestions for better, I’d love to hear it, but at the moment this is the best I can do. I tried to follow several tutorials on making water for Poser… None of what resulted looked like what I wanted- slightly blueish lightly rippled CLEAR water… like in a pool. That is in regards to Poser… DAZ Studio’s materials is whole separate system I still have to understand, so sorry.
In Poser the water is set for displacement, so you’ll have to remember to render using displacement and in DAZ studio you’ll have to manually set the displacement maps… Good luck… I got one render that the water looked okay in and then someone tripped the fuse before I could save anything… so I have no idea what the settings where… Fate sucks.
I hope you like and or can use it. I’d also be real happy to see any renders you make with it, if you do use it.
Caprinia Pavilion- DS4 Pro RenderCaprinia Pavilion- Poser Pro 2010 RenderCaprinia Pavilion- Aerial view
foxylady1 posted Fri, 31 August 2012 at 11:16 AM
Thank you, this is really detailed.
bobbystahr posted Fri, 31 August 2012 at 1:16 PM
very noce contribution...thanks for sharing this
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
SamTherapy posted Fri, 31 August 2012 at 2:09 PM
Lovely work.  Many thanks.
PilotHigh posted Fri, 31 August 2012 at 4:58 PM
Thank you so much!!
Miss Nancy posted Fri, 31 August 2012 at 6:41 PM
it looks great!
bobbystahr posted Sat, 01 September 2012 at 12:52 AM
Just converted it for Terragen 2 and looks great so far...lighting is gonna be a trick
I see a sound
Larry F posted Sat, 01 September 2012 at 1:20 AM
That's a terrific piece of work.  THANK YOU!!!
