Subject: color light problems
xpdev opened this issue on Sep 03, 2012 · 9 posts
xpdev posted Mon, 03 September 2012 at 5:35 AM
1 light WHITE
1 One Skydome with a sky picture it is normal that the shadows become blue?
The material does not have reflections, but the shadows are toward the blue.
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
deck
xpdev posted Mon, 03 September 2012 at 5:36 AM
sky dome setting
cspear posted Mon, 03 September 2012 at 5:50 AM
I suspect that the blue colour is simply too strong - it looks very unnatural.
Here's a shader setup for a clear blue sky (I use it applied to BB's EnvSphere).
PoserPro 11 - Units: Metres
Adobe CC 2017
xpdev posted Mon, 03 September 2012 at 5:59 AM
hum... possibile....
may you tell me te values for the 4 blu color and open then V_texture coordinate so i make some tests.... ?
many thnaks.
cspear posted Mon, 03 September 2012 at 6:17 AM
Here's an mt5 file (take the .txt extension off the filename).
But note that there's nothing in the v_texture_coordinate node to modify, you need to control it using math nodes.
Adobe CC 2017
xpdev posted Mon, 03 September 2012 at 6:20 AM
Many thanks..... but how may use the mt5 file ?
sorry......
ok, found the way....
i'll do some test....
cspear posted Mon, 03 September 2012 at 6:25 AM
Put it in runtime : libraries : materials : [your folder name]
Then apply it to something like BB's envsphere.
Adobe CC 2017
xpdev posted Mon, 03 September 2012 at 6:33 AM
OK, many thanks, seems better.....
