Subject: poseray
darquevision opened this issue on Sep 07, 2012 · 8 posts
darquevision posted Fri, 07 September 2012 at 3:53 AM
i am wondering how export a certian "group" in poseray. i have come across a lightwave file that contains several items which are grouped per item. i can view them seperately but cant export each group indiviually. is there a way?
i am extremely new to poseray and have basically used it once to export some vehicles which textures got lost in a direct import to poser.
thank you in advance
CyberDream posted Fri, 07 September 2012 at 11:11 AM
You go to "Groups" tab and left-click once on the icon at left, that will hide it.
PoseRay will only export the groups that are visible (it skips hidden ones)
darquevision posted Fri, 07 September 2012 at 12:17 PM
 i have tried that seems to only keep the file hidden however the actual file still contains the "full" file. i thought they were skipped but when checking "groups" they are there and can be unhidden. the exported obj it is still full as well
ty for the response
CyberDream posted Fri, 07 September 2012 at 12:40 PM
I checked before posting (in case memory failed) and for me it only exports visible Groups and the material associated with that group (you don't have to hide both).
I am using version 3.12.2.456 which is current non-beta version
darquevision posted Fri, 07 September 2012 at 1:39 PM
i just checked mine and i am running the beta version- that might be the issue then.
is the non bata vision available for free also?
again thank you for the responses
CyberDream posted Fri, 07 September 2012 at 2:58 PM
I just tried the beta and group export does not work the same as regular.
The regular version is also free at
https://sites.google.com/site/poseray/home
darquevision posted Fri, 07 September 2012 at 3:11 PM
awsome- ty for the link.
plus i am glad it was just due to the version i was using rather than my lack of knowledge.
again ty i am going to dl it now.
darquevision posted Fri, 07 September 2012 at 3:38 PM
i just realized after looking a bit closer- there is an option "remove non visible groups" in groups that sorted it out- it also worked fine in beta.
at any rate ty for your help
