Subject: Problem with geometry
JIMMYJOHN opened this issue on Sep 27, 2012 · 5 posts
JIMMYJOHN posted Thu, 27 September 2012 at 3:24 PM
Hello,
I make simple geometries in 3DSMax, I can texture them alright and they render fine:
 http://bayimg.com/ADDhNaAec
I then import them in POSER (as 3DS or OBJ). Most of the time it works fine, but sometimes, it goes awry, some faces disapear:
 http://bayimg.com/AADHpaaEC
I've tried different paramaters to no effect.
Any ideas, please?
MistyLaraCarrara posted Thu, 27 September 2012 at 3:29 PM
you could try checking the direction of the normals?
JIMMYJOHN posted Thu, 27 September 2012 at 4:02 PM
Thanks Princess, but I'm afraid I don't understand. Where can I find those directions?
Santel posted Thu, 27 September 2012 at 4:17 PM
While not exactly what misty wrote, you can experiment with the options on import of objs, as in 'make consistent' or 'flip' or both. If the model has them facing differently in different parts, and if they're separate as in 'groups' you might also be able to get some help in the group editor but this all depends on your model. All this because when the normals face inwards, the faces either look inverted or invisible.
JIMMYJOHN posted Thu, 27 September 2012 at 4:51 PM
OK! Still not working when importing 3DS, but problem solved for OBJ with "make polygons normals consistent" checked.
Thanks to you all. This forum is a miracle, it has helped me out of dead ends so many times!
