Forum: Vue
Subject: ah ha! found how to get area lights "invisible but working" again :P
silverblade33 opened this issue on Sep 29, 2012 · 6 posts
silverblade33 posted Sat, 29 September 2012 at 6:44 AM
man I have the memory of a ZX Spectrum after a nuclear test :P
anyway, years ago, the easy way to get a great effect for a render was to make an object an "area light", then hide the area light object by merely turning it to "hide from render" but it would leave the light still working.
Alas now that turns the light off, as well, doh.
Anyway, easy way to do it is to make a new layer, set that layer to invisible, then in render settings, set it to render ONLY VISIBLE LAYERS
so you get the great effect of an area light, but the object the area light is made from, is hidden! :)
ok why use area lights?
they are far far more realistic, because in real life, light NEVER comes from a single point, save for a laser/Big bang :P
I also found ages ago that duplicating an object, making it an area light, can make lots of great special effects, like magic glowing swords/potions etc
of course with radiosity any material set to have some degree of "Luminous" will literally shed light, but nto quite same as an actual light
Think I found this trick before and posted it here, but hey as said , my memory is shot to bits :P making new tutorial on shadows/light anyway ;)
my tutorial on lighting in Vue, need to update it again in "light" of this "illuination" of mine...sorry, too much Terry Pratchett: one must pun! ;)
http://www.silverblades-suitcase.com/tutorials/htm/22.html
sword's blade and potion liquid duplicated made into area lights from old tutorial
 where this stuff comes in real handy is say, light from lava, a forge etc, throwing light from broad area looks way more realistic, and in general for indoor stuff it's better than a point light, but it is slower to render
