Forum: DAZ|Studio
Subject: where does michael 5 go in DAZ studio?
iborg64 opened this issue on Oct 13, 2012 · 11 posts
iborg64 posted Sat, 13 October 2012 at 2:52 PM
just bought michael 5 for DAZ studio but when I run the installer I get an error "michael 5 is an add on for Genesis and they must be installed in the same location"
whats it looking for , as always I installed DAZ studio to default location so I expected DAZ installers to know where everything should go anybody know exactly where to put it ?
26Fahrenheit posted Sat, 13 October 2012 at 3:05 PM
M5 is a Morph for genensis ... not a figure itself .. so you need to have Gn installed etc etc
Chris
HERE are my FREEBEE's
iborg64 posted Sat, 13 October 2012 at 3:12 PM
I must have Genesis (I think ) because victoria 5 works ok
animajikgraphics posted Sat, 13 October 2012 at 3:39 PM
I have had similar issues with installs - it's just a matter of telling the installer where to put the files.  For the most part, the installers "get it right", but every once in a while it loses the correct path.
Should be something like (yours may be different):
../My Library/PeopleGenesis
Do another install and make sure it's going to the correct path.
-AniMajik
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
iborg64 posted Sat, 13 October 2012 at 3:44 PM
Just tried that still get the same error is there a file its looking for in that location? definately have genesis as victoria 5 works and female Genesis characters work as well
RHaseltine posted Sat, 13 October 2012 at 4:29 PM
My Library should be the default target, unless you chose a different location for the content. The folder you isntall to should already contain DataDAZ 3DGenesisGenesis.dsf (and you install to the folder that holds the data folder, not the Genesis folder itself).
iborg64 posted Sat, 13 October 2012 at 4:47 PM
yes tried that everything was left as default when installing DAZ studio so following from the two answers above file path should be Cusersmy namemy documentsDAZ3Dstudiomy librarydataDAZ 3DGenesis
and that it is where I try to install it , to the my library where the Data folder is do you know what file it is looking for ? maybe I could try to find it manualy first
iborg64 posted Sat, 13 October 2012 at 6:30 PM
I have tried a reinstall still wont work anyone know the exact file its looking for maybe if ii can find that i can point it in the right direction
ldgilman posted Sat, 13 October 2012 at 10:35 PM
At least you are not alone with this issue, I am having the same issue that you are, and awaiting an answer so I/we can get going again.
RHaseltine posted Sun, 14 October 2012 at 9:11 AM
Quote - yes tried that everything was left as default when installing DAZ studio so following from the two answers above file path should be Cusersmy namemy documentsDAZ3Dstudiomy librarydataDAZ 3DGenesis
No, the path should be C:usersmy namemy documentsDAZ 3Dstudiomy library - the Data and so on foldrs are created/merged with by the isntaller, you just tell it where they are.
iborg64 posted Mon, 15 October 2012 at 2:13 PM
hooray fixed it, a search of my entire hard drive for Genesis.dsf found the only copy was in C:Program FilesSmith MicroPoser Pro 2012dataDAZ 3DGenesisBaseUV SetsDAZ 3DBase so copied it over to the correct place and the installer worked no idear what it was doing there as the only place must have been something to do with updateing DAZ studio and or the installation of Dson
