Anthony Appleyard opened this issue on Oct 21, 2012 · 6 posts
Anthony Appleyard posted Sun, 21 October 2012 at 7:21 AM
import poser
import string
import aasubrs
reload(aasubrs)
scn = poser.Scene()
for a in scn.Actors():
if a.IsLight():
print "found light ",a.Name()
a.SetShadow(1)
a.Set??????????(0.5)
poser.ProcessCommand(1559)
#scn.DrawAll();
In this Python script, as run under Poser 7, what Poser Python function should I call to set the parameter called "Shadow" in a light's parameter box in Poser 7?
PhilC posted Sun, 21 October 2012 at 7:40 AM
In Poser 7 I see the checkbox "Shadows".
The Python method is:-
SetShadow(1) #shadows off
SetShadow(0) #shadows off
The dials are set with:-
SetShadowBiasMax(value) # float value
SetShadowBiasMin(value) # float value
SetShadowBlurRadius(value) # float value
If I recall correctly the Properties panel will not update unless you manually force it by switching to the Parameters panel and back again.
Anthony Appleyard posted Sun, 21 October 2012 at 7:58 AM
Dizzi posted Sun, 21 October 2012 at 10:20 AM
p=a.ParameterByCode(poser.kParmCodeDEPTHMAPSTRENGTH)
p.SetValue(0.5)
markschum posted Sun, 21 October 2012 at 11:06 AM
In Poser 7 you can use lites = scn.Lights() instead of getting and filtering the actors list.
Anthony Appleyard posted Sun, 21 October 2012 at 11:50 AM
Thanks. It works.
import poser
import string
import aasubrs
reload(aasubrs)
scn = poser.Scene()
if a.IsLight():
a.ParameterByCode(poser.kParmCodeDEPTHMAPSTRENGTH).SetValue(0.5)
a.SetShadow(1)
#scn.DrawAll
