ObscuroArcanum opened this issue on Nov 02, 2012 · 16 posts
ObscuroArcanum posted Fri, 02 November 2012 at 4:41 AM
I'm using PP2012, 64-bit version. This is my first image in PO2012.
Anyone know what is happening with the hair, or how I might fix it?
vitachick posted Fri, 02 November 2012 at 4:57 AM
Hope someone can help u. Right now she needs a haircut real bad..
Win10 Poser 2014/Poser 11 Daz3D
ObscuroArcanum posted Fri, 02 November 2012 at 5:01 AM
For sure! She is looking more like Cousin It from the Addam's family, than the Alma-esque look I'm aiming for. Didn't have a chance to do anything else, before the hair decided "nope, not going to cooperate"
I'm not sure if it's a K4 issue, with hair or not, because this is the first time I've used the model. I tried the hair on V4 and it behaved itself when I confirmed it to V4's head...
vitachick posted Fri, 02 November 2012 at 5:03 AM
Maybe it only works with Daz??
ObscuroArcanum posted Fri, 02 November 2012 at 5:06 AM
The product page says it works for both DAZ and Poser.
And if the hair doesn't work in Poser, then it shouldn't have worked when I conformed it to V4.
The hair looks normal when I load it; it's only when I try and conform it to K4's head that it goes berserk
vitachick posted Fri, 02 November 2012 at 5:08 AM
Good luck! Maybe the vendor can help? I'm sure someone will be posting soon to help u with the shaggy dog look problem..
ObscuroArcanum posted Fri, 02 November 2012 at 5:12 AM
Thanks!
If no one has any ideas in the thread, then I'll shoot off a message to the vendor.
WandW posted Fri, 02 November 2012 at 6:18 AM
There is a fit pose for K4 in the MAT PureVelvetHair folder. It looks like a scaling issue....
"Oh - the manual says that? I have never read the manual - this must be why."hborre posted Fri, 02 November 2012 at 6:26 AM
If it is a scaling problem, PP2012 has scaling fix in the properties panel for the hair. Try activating that. But, as WandW posted, if there is a fit pose available, you may need to inject that in first before conforming and spinning the dial.
Glitterati3D posted Fri, 02 November 2012 at 7:02 AM
Here, I've used Style 07 after using translate to move the hair into position. I also used the "Baby Fit" morph to get it a bit more round.
on edit:
Ooops, there IS a fit morph in the Pose folder for K4, but you have to use the Prop hair for it to work.
Glitterati3D posted Fri, 02 November 2012 at 7:32 AM
ObscuroArcanum posted Fri, 02 November 2012 at 7:53 AM
I feel quite foolish now. I didn't realise there was a second version of the hair included. I was using the V4 prop from the Figures folder, I didn't know there was another option under Hair that the K4 fix was designed for.
Thanks for everyone's help. I've got the hair okay now :D
Glitterati3D posted Fri, 02 November 2012 at 8:05 AM
Quote - I feel quite foolish now. I didn't realise there was a second version of the hair included. I was using the V4 prop from the Figures folder, I didn't know there was another option under Hair that the K4 fix was designed for.
Don't feel foolish, we've all done it a time or two. :-)
ObscuroArcanum posted Fri, 02 November 2012 at 8:10 AM
That is comforting to know!
I am used to Hair props I have bought either being in the Figure folder, or under the Hair tab... I've never had a prop that came under both. I assumed, incorrectly as it turns out, that Pure Velvet with those morphs for the extra characters behaved like other Hairs I'm used to.
Glitterati3D posted Fri, 02 November 2012 at 3:34 PM
Quote - That is comforting to know!
LOL, look at my first response to you - I did it all wrong. :-)
It's really easy to miss the fact that the vendor included a Prop hair for a reason.
ObscuroArcanum posted Sat, 03 November 2012 at 12:38 AM
Absolutely!
But it's all sorted now, so I'm back to making my scene :D
