martial opened this issue on Nov 08, 2012 · 14 posts
martial posted Thu, 08 November 2012 at 4:52 PM
Bonjour
I just reinstall Poser pro 2012 in my new computer
Everything seems good with Poser except this
when i click on rendering i got everytime this message:
'' Texture could not be loaded ,image map could not be found or there is not enough memory ''
Sure i have enough memory (i get 32 gigs on my new system) What else is wrong?
I use Poser since vesion 2 .May be in the past i got this message but i don't reember what to do with this
Since version 7 i never got a message like that
Some suggestions??
Thanks
martial posted Thu, 08 November 2012 at 4:54 PM
My system is Intel I7 3770,with windows 7 pro,Video card GFORCE GTX 660,32 gis ram, intel ssd 240 gigs (my OS),and two others hard drive
RedPhantom posted Thu, 08 November 2012 at 5:24 PM Site Admin
I'm no expert but 2 things it might be is the textures are in a runtime that isn't in poser's library any more. Perhaps a different drive letter or directory than it was in the past. Or you might need to switch the file search to deep in the preferences.
LaurieA posted Thu, 08 November 2012 at 5:37 PM
Go into the General Preferences and render to a "Separate Process" and set the cores to the amount of cores on your processor. Might also check Texture caching in a background thread. You might also take heed to what RedPhantom said and see if the textures are missing for the item/s you are trying to render and/or set the search to deep.
bagginsbill posted Thu, 08 November 2012 at 11:49 PM
It says: image map could not be found OR there is not enough memory
It does not say: there is not enough memory
You have tons of memory, so guess what it is?
martial posted Fri, 09 November 2012 at 4:15 AM
I got the problem with different scenes already saved when i had my old computer and where they was ok for rendering before
I think also the problem is related with the localisation of the maps But for now i can not know how to solve it. May be during the week end i will try to uninstall -reinstall and see what happen
i have just reinstalled Poserpro pro and sr1 to sr 3,1 in my old folder of Poser pro 2012 because there were a ton of data there with a very hurge libraries there and in others runtime ---these others runtine are installed in older Poser 7 and Poser 6 and Poser 5 folders ,referenced in Poser pro 2012 and all installed in E:
And i am using XL Dimension3d for managering all my libraries This installation were working perfectly before in my older system
I also reproduce the older parameters used by Poser before in Users and program data in c:|
hborre posted Fri, 09 November 2012 at 7:27 AM
Reinstallation will not accomplish anything, you will still have the old problem. You will need to manually redirect the image map pathway on the new computer and afterwards resave the scene.
wimvdb posted Fri, 09 November 2012 at 7:52 AM
If the scene loads without errors and the error appears only when rendering, the problem may be that a bump or specular or displacement map cannot be found.
The question of which texture is missing can be done in two ways - either by going into the material room and check each material of an attached texture (bump, disp or spec) is empty or is show as completely white - or by turning on the texture search log (WRITE_FILE_SEARCH_LOG 1 in poser.ini) and checking the log for the name of the file when the error occurs. Logfile is located in users/
Checking in the material room is the easiest if it is a small scene, but if it happens more often, turning on the logfile is more convenient.
Possible culprits are a non-present texture, an incompatible texture (shows as white), or an empty image node which is connected
martial posted Fri, 09 November 2012 at 12:02 PM
Thanks for your suggestion wincdb
i will check
It was strange to me that the scenes already saved are loaded with the textures and were ok on the screen ,so maybe the maps were at the good places But when rendering Poser not find it in the place it find when open the scenes
wimvdb posted Fri, 09 November 2012 at 12:16 PM
The bump and displacement maps are not loaded in preview - only when you render, so before that it has not encountered the missing textures
martial posted Fri, 09 November 2012 at 2:22 PM
Merci beaucoup LaurieA
You have the other part of solution
I change these settings in the preferences and everthing seems good now with rendering
In document:
optimization: select multithresd bending
In render
number of thread :8 (i have now I7 3770)
select run in background thread
Voila! it working good now
wimvdb posted Fri, 09 November 2012 at 2:26 PM
Quote - Merci beaucoup LaurieA
In document:
In render
Are you running the 64bit version of Poser? Because if you run out of memory, it looks like you are running the 32bit version. You have an i7, PP2012, so we assumed you did - but that should not run out of memory
martial posted Fri, 09 November 2012 at 2:31 PM
I am running a 64 bits version and i think my problem was really in the preferences not with memory
When i change some parameters like LaurieA suggest my problem was solved Hope this solution will be a correct one also for some others with the same situation
LaurieA posted Fri, 09 November 2012 at 6:10 PM
FWIW, I could never run a Poser version from 7 and above without turning on "Separate Proces" I'd freeze, I'd crash, I'd get out of memory errors. I however, only have 6 gigs of ram...lol (wish I had 32...hehe).
