Subject: Installing Poser 9 - Tips?
sdsullivan opened this issue on Nov 15, 2012 · 7 posts
sdsullivan posted Thu, 15 November 2012 at 12:01 PM
Thanks to Rendo, I just got a great deal on Poser 9, so I’ll be installing that to replace P7, which I’m currently using.
But, before I do, I wanted to get some tips—especially about my current runtime.
If I just straight instll P9, will it leave the P7 runtime alone?  Can I just install and then point to the existing runtime in the new P9 library?
Is there anything special I should do to protect the original runtime?  Should I leave it where it is (P7)?  Should I move it somewhere?
Anything else I should know or be wary of.
I’m running a Win7 PC with 4g of ram & some kind of standard graphics card, nothing fancy.
I look forward to your wise advice.
Thanks!
 Stephen D. Sullivan
www.stephendsullivan.com
Adventure guaranteed.  (Monsters optional.)
LaurieA posted Thu, 15 November 2012 at 12:14 PM
You can point to the Poser 7 runtime. Just be advised that if you run Windows Vista/7/8 that UAC will apply, so do not install content to your Poser runtime if you have UAC turned on. During the install it will create a content runtime in your Documents folder.
You can either move the Poser 7 runtime or leave it where it is if you think you may still want to use it from time to time. Poser 9 will not overwrite your Poser 7 install. You can point to it where ever it is.
sdsullivan posted Thu, 15 November 2012 at 12:54 PM
Quote - You can point to the Poser 7 runtime. Just be advised that if you run Windows Vista/7/8 that UAC will apply, so do not install content to your Poser runtime if you have UAC turned on. During the install it will create a content runtime in your Documents folder.
What is UAC?  And am I likely to have it turned on without knowing it?
 Stephen D. Sullivan
LaurieA posted Thu, 15 November 2012 at 1:56 PM
UAC is User Account Control and if you don't know what or where it is, it's already on ;). It's on by default. It's meant to keep bad programs and viruses from writing to anything in your Program Files (x86) and Programs (x64) folders.
sdsullivan posted Thu, 15 November 2012 at 2:17 PM
Oh, THAT thing.
If it puts my (new) runtime in documents, is that a problem?
On the old one, I installed Poser 7 directly on C-drive, avoiding the UAC, I guess.
Obviously, I don't want UAC or anything screwing up P9, but I do want to try and keep this install simple.
I haven't had any trouble with P7, but no sense buying trouble down the line.
-- Steve
Quote - UAC is User Account Control and if you don't know what or where it is, it's already on ;). It's on by default. It's meant to keep bad programs and viruses from writing to anything in your Program Files (x86) and Programs (x64) folders.
 Stephen D. Sullivan
vilters posted Thu, 15 November 2012 at 3:02 PM
Do yourself a favor.
Do the default install, and yes it will put the P9 Runtime in "my documents".
Thats good.
Poser9 will create its own runtime to work in c/program files. Do not touch that one.
Your P9 content will be in your "My docuents" folder.
And yes you can link to your P7 runtime, no problems there.
sdsullivan posted Thu, 15 November 2012 at 3:04 PM
Thanks so much!  Sounds like an easy install.
(And hopefully it will be!)
 Stephen D. Sullivan
