madmitch opened this issue on Nov 20, 2012 · 6 posts
madmitch posted Tue, 20 November 2012 at 8:31 AM
When I set up a scene, I normally create a camera, set it to the position I want, then lock the translation and rotation controls, and use the perspective view to change the figures / props in the scene. This worked Ok until I bought a new 64 bit computer and installed the 64 bit version of DAZ Pro 4.5 Now if I lock the camera controls and save the file, close DAZ , re-open DAZ and reload the file ( simulating a new work session) the camera has moved to a different position. Perversely, if I don’t lock the camera controls and carry out the same procedure, the camera remains in its set position. Does anyone know what’s going on? Because of the way I work, I would like to be able to lock the camera.
RHaseltine posted Tue, 20 November 2012 at 8:59 AM
Have you tried Memorising the camera (Parameters pane option menu), then you can Restore it if it gets moved in error. Not that the behaviour you are seeing isn't worth a bug report, of course.
madmitch posted Tue, 20 November 2012 at 10:34 AM
Yes that works Richard. I didn't expect the memorised data to be retained through a save , close, open cycle but it is. Many thanks.
Presumably the bug reporting is on the DAZ site?
RHaseltine posted Tue, 20 November 2012 at 2:08 PM
Yes, bugs.daz3d.com - if you haven't created an account you will need to, it doesn't share the forum and store details.
Razor42 posted Tue, 20 November 2012 at 10:03 PM
With larger scenes it may also help to save the camera as a Camera Preset that way you can reload it to position at any time.
madmitch posted Wed, 21 November 2012 at 2:02 PM
Thanks guys
