Mazak opened this issue on Nov 24, 2012 · 32 posts
Mazak posted Sat, 24 November 2012 at 6:00 AM
Attached Link: http://www.e-onsoftware.com/resources/?page=updates
Vue 11 Infinite - Build 11003442 - BETA The following is a list of bug fixes and improvements included in this update:Publishing Date: Public Beta: 11/23/2012
Paloth posted Sat, 24 November 2012 at 11:09 PM
Did the installer work for you?
Mazak posted Sun, 25 November 2012 at 6:35 AM
Yes the installer work for me. I use Vue 11 Infinite you must downlod the Vue 11 xStream** **patch.
Mazak
estherau posted Sun, 25 November 2012 at 4:00 PM
the import is improved of poser genesis, however the skin is still all wrong. eyes look okay but the skin looks like the UV is wrong or something.
Love esther
estherau posted Sun, 25 November 2012 at 4:01 PM
estherau posted Sun, 25 November 2012 at 4:07 PM
even keeping poser textures doesn't help. The same problem with the skin occurs.
Paloth posted Sun, 25 November 2012 at 10:56 PM
Does this happen with every figure?
Vege-Mite posted Mon, 26 November 2012 at 4:08 AM
As far as I know it only happens with the new DAZ Genesis figures; Victoria 5 and Michael 5. Importing as an OBJ doesn't help either. Vue Tech support have known about the problem for quite a while. I now use DAZ Studio for those charcters.
Adriaan Barel (a.k.a. Vege
Mite)
"Morality, like art, means drawing a line someplace." --
Oscar Wilde
estherau posted Mon, 26 November 2012 at 5:02 AM
I have only tested michael 5 and victoria 5 and it happens with them. I was hoping the new beta would fix it but although the geometry looks far better in vue than it did with the previous version, the texture on genesis look like I showed you in the pic.
Mazak posted Tue, 27 November 2012 at 9:24 AM
Mazak
estherau posted Wed, 28 November 2012 at 4:24 AM
well I used the mec4d script to convert my M5 to M4 UV map and applied a M4 texture that looked fine in poser, but did not import into vue. I haven't tried V4 texture on V5 yet though.
Love esther
estherau posted Wed, 28 November 2012 at 8:48 AM
Okay I used same script to make the genesis figure take V4 textures, and the V4 textures weren't perfect ie you could see a faint line between the forearm and arm etc but the big white patches were gone.
However after Imoprhed her I had clothing poke thru, so I ran the morph follower script and now when the figure renders in vue you get a double figure with one in default position. although the preview image doesn't have this.
Love esther
Eric Walters posted Wed, 05 December 2012 at 10:23 PM
Ah good! I just installed Vue11 Inf this week. Good to know they are working on an update with the Sept 2012 SDK! I need to get into the Beta program....
estherau posted Thu, 06 December 2012 at 7:41 AM
Masai your textures aren't perfect. look closely at her arms. U can see faint lines where different texture maps meet.
Eric Walters posted Sun, 09 December 2012 at 9:05 PM
Can someone please try loading a test scene- say "Tea for Two" from Samples 3, then merging a simple scene-say V4 alone-imported and saved as a Vue file. I can't seem to make it work with Vue Inf11 (beta updated). The same works with Vue 9 Infinite.
estherau posted Sun, 09 December 2012 at 9:49 PM
Love esther
PS did you get my PM the other day?
estherau posted Sun, 09 December 2012 at 9:57 PM
Oh I think I know why the render turned black. It's because I should have kept poser materials as I did some tooning. I think
estherau posted Sun, 09 December 2012 at 10:24 PM
Yes, just tried itin one of the sample scene 3 and it is fine. Have you selected the correct poser SDK and folder.
Eric Walters posted Mon, 10 December 2012 at 9:39 PM
Hi Esther
I just did! How much RAM do you have. I wonder if it's my 7Gigs.
Quote - I just tried. the preview looks okay but the render turns the figure black!!! eeeek
Love esther
estherau posted Mon, 10 December 2012 at 11:09 PM
I have 56GB of RAM. I don't know if it helps or not. Perhaps a different video card would help more.
Mazak posted Fri, 21 December 2012 at 3:53 PM
NEW Beta:
Vue 11 Infinite - Build 11004282 - BETAThe following is a list of bug fixes and improvements included in this update:
Publishing Date: Public Beta: 12/21/2012
Eric Walters posted Sat, 22 December 2012 at 2:46 PM
Thanks Mazak!!
Eric Walters posted Thu, 27 December 2012 at 2:25 AM
I was unable to do this-merge two scenes-with V11 INF-prior to the update.
http://www.renderosity.com/mod/gallery/index.php?image_id=2397181
Mazak posted Thu, 27 December 2012 at 4:26 AM
Eric Walters posted Thu, 27 December 2012 at 2:23 PM
Thanks Mazak
I did'nt. It comes with the AM Smilodon- it is fiber mesh. It takes hours to render with IDL in Poser-but minutes in Vue.
The trickiest part of this render was scaling and camera positioning.
Mazak posted Thu, 27 December 2012 at 2:52 PM
Mazak
Eric Walters posted Thu, 27 December 2012 at 2:57 PM
Nice Bear! Ages and a little more I suspect!
AM has a Bear with fur-I think.
Quote - Ahh fiber mesh hair. A while ago I rendered this Grizzly from Poser with dynamic hair, it took ages for this render. :-/
Mazak
Mazak posted Thu, 27 December 2012 at 3:08 PM
This is the Grizzly I have. It's the one with Poser hair.
http://contentparadise.com/productDetails.aspx?id=13961
Mazak
Eric Walters posted Thu, 27 December 2012 at 7:51 PM
Mazak
Thanks for the link! I've not bought from CP in a long time-now I see several fun items to buy!
Eric
Mazak posted Fri, 28 December 2012 at 2:23 AM
Ja the Vendor has moved to CP. I purchased the item here at renderosity too. Google is your friend.. hrhrhr :D
Mazak
