xpdev opened this issue on Nov 27, 2012 · 6 posts
xpdev posted Tue, 27 November 2012 at 9:31 AM
it is some time that when I add a new link (to a dress or something other) to the poser library , poser takes about 1 minute or more to add the new folder, regardless of the size of the content.
hd is an independent partition (different from the operating system) and has still 112GB free of a total of 200.
you have any suggestions?
thanks
Poser Pro 2014 SR 1 on Windows 7 64
bit
I use IDL, Gamma Correction and EZSkin for all
final renders.
LaurieA posted Tue, 27 November 2012 at 10:33 AM
Have you updated Flash in awhile? (remember, you have to update Flash to your system, but to Internet Explorer too, even if you don't use it). You might try updating Adobe Air too (I don't know what version of Poser you have).
Edit: OK, you have Poser Pro - update Adobe AIR. May as well do Flash too just to cover all the bases. You can also try clearing your Poser cache.
xpdev posted Tue, 27 November 2012 at 10:38 AM
Many thanks.
bit
final renders.
xpdev posted Wed, 28 November 2012 at 4:57 AM
I have update this:
Adobe Air 3.5.0.600
Adobe Flah Player 11 Activex 11.5.502.110
Adobe Flah Player 11 PlugIn 11.5.502.110
Poser library still slow to load new links to a runtime folder, about 1 minutes or more.
Other ideas.
Many thanks.
bit
final renders.
xpdev posted Wed, 28 November 2012 at 6:06 AM
Cleared Poser cache.
Reinstallend Poser...
Always slow.....
bit
final renders.
Bothellite posted Sat, 22 December 2012 at 10:03 PM
My resources were not appearing in Poser Pro 2012 -- all of a sudden. It said to dowload the latest version with a link that didn't work very well.. on the troubles went.
If anybody is having trouble updating Flash player there are some real problems updating in both IE and Firebox. I searched and searched, Googling and Bing'ing...
This install worked FINALLY, after all kind of "time out" failures.
This install does not depend on Active X.
http://ezref.info/Download+Timeout+at+12%25+when+downloading+Adobe+Flash+Player.html
