Ravyns opened this issue on Dec 02, 2012 · 7 posts
Ravyns posted Sun, 02 December 2012 at 6:58 PM
Life may not be the party we hoped for but while we're here we should dance.
skiwillgee posted Sun, 02 December 2012 at 9:52 PM
That may be difficult to convey since flickering is a change of light value over time. Unless it is animated you are constrained to a single moment in time.
That said, could you do something to soften that hard line shadow. A flame is emitting light from its entire visible surface and not a a singular point.
You could try using some sort of gel with the light source. It will be difficult, indeed.
skiwillgee posted Sun, 02 December 2012 at 9:54 PM
Consider turning off cast shadow on the object that is causing the shadow as an experiment. I really like the lighting along the book tops to the left.
Ravyns posted Mon, 03 December 2012 at 8:47 PM
Thanks Much skiwillgee.
I was thinking that a candle might cast a flickering shadow so I did a test with a candle in the kitchen. As long as there's no air to move the flame it looks pretty much like the lighting in the image. Guess I was thinking sort of wrong. LOL . It did make hard shadows, a little sharper then the image ones, so I guess I'll just leave this alone.
skiwillgee posted Tue, 04 December 2012 at 3:22 PM
Kudos for you to be thorough enough to light a candle and observe it in the real world. Observation like that will surely show in your art.
clay posted Tue, 04 December 2012 at 4:22 PM
Attached Link: http://www.baument.com/restore/Tutorials/flameon.html
Try this, my fire material isn't suited for candles, but this should work for ya:-)Clay
Do atleast one thing a day that scares the hell outta ya!!
Ravyns posted Tue, 04 December 2012 at 9:59 PM
Thanks Much for the link Clay. I discovered right away that your fire didn't work. I use it a lot so it's the first one I tried. I ended up using one of the materials that came with Bryce but it's not showing up very good. I'll try that tutorial tomorrow. Maybe I'll get lucky & get it right the first time..LOL ..
