lionhead07 opened this issue on Dec 04, 2012 · 4 posts
lionhead07 posted Tue, 04 December 2012 at 4:07 AM
i have created a forest and the trees,added variable scale and it worked fine, but when i went into the advance editor/color then check the variable color check box, added the gradient present(FIELDS) all my tress went black and the gradient is not even close to black . Does anyone know whats happening her? im using VUe 9.5 on a Mac pro Lion OSX 10.7
thank you!
ShawnDriscoll posted Wed, 05 December 2012 at 5:14 AM
It's a bug that comes and goes. Adjust the colors of the trees first. Then do the scaling.
bruno021 posted Wed, 05 December 2012 at 5:42 AM
Variable colors needs a fucntion and a color map. If no function, only one color is applied. Also note that the varioation will be applied to leaves AND trunks, and the result might look odd. Don't use 100% of color variation.
lionhead07 posted Thu, 06 December 2012 at 9:57 PM
ok i will try that thanks guys
