GKDantas opened this issue on Dec 06, 2012 · 7 posts
GKDantas posted Thu, 06 December 2012 at 6:58 PM
Follow me at euQfiz Digital
LaurieA posted Thu, 06 December 2012 at 7:09 PM
Um, the dark blue lines are the shadow inside the wrinkles/puckers in the fabric there at the ring. It's supposed to be there.
CaptainMARC posted Thu, 06 December 2012 at 7:46 PM
Either decrease shadow amount or increase shadow minimum bias. Or both. Or just change your lighting completely. Or use IDL.
hborre posted Thu, 06 December 2012 at 8:14 PM
It appears that Shadow Min Bias is set too high on your main light. There is a lack of bikini shadowing where the material meets the skin. Try a value of 0.1 for starters.
And just for more complete info, provide which Poser version used and present OS. We can get a better accessment and recommend an accurate resolution.
GKDantas posted Thu, 06 December 2012 at 9:25 PM
Hi people, thansk for the answer so far. I am using Poser 2012 in Windows 8 Pro 64 bits.
Looks that the problem is related to the bump channel, when I increase it I get more artifacts.
This light set is an old GI rig, I will try more lights tomorrow, after fight with the bumps that is really different from others like Lightwave or Carrara.
CaptainMARC posted Thu, 06 December 2012 at 9:41 PM
Ah well, you got the bump self shadowing. Fiddle with shadow minimum bias. I think it has to go up, Superman thinks it has to go down. He's probably right, I'm only a beginner. No matter, try either. If it gets better, try more, if it gets worse, try the other direction.
bagginsbill posted Thu, 06 December 2012 at 10:48 PM
You have demonstrated, once again, that in Poser neutral bump or displacement is not gray, it is black.
Subtract .5 from the bump map.
