Paul Francis opened this issue on Dec 14, 2012 · 7 posts
Paul Francis posted Fri, 14 December 2012 at 7:19 AM
Hi folks, I'm stuck and need help!
I have a prop of a small building which features a hanging lamp and various other bits and pieces. I need to extract the lamp from the rest of the model to re-position it within the scene, but as usual Poser loads the whole building as a single prop. I note that in the material room, each piece of the moel has it's own material group, so much so that I can make all the other bits of the model invisible within the material room, but find that the invisibilised bits are casting weird artefacts.
Is there any way in Poser to ungroup the polygons in the original model into their component parts, so I could just load the lamp bit?
My
self-build system - Vista 64 on a Kingston 240GB SSD,
Asus P5Q
Pro MB, Quad
6600 CPU, 8 Gb Geil Black Dragon Ram, CoolerMaster HAF932 full
tower chassis, EVGA Geforce GTX 750Ti Superclocked 2 Gb,
Coolermaster V8 CPU aircooler, Enermax 600W Modular PSU, 240Gb SSD,
2Tb HDD storage, 28" LCD monitor, and more red LEDs than a grown
man really
needs.....I built it in 2008 and can't afford a new one,
yet.....!
My
Software - Poser Pro 2012, Photoshop, Bryce 6 and
Borderlands......"Catch a
r--i---d-----e-----!"
ockham posted Fri, 14 December 2012 at 7:31 AM
Assuming this scene is all one OBJ file: The simplest trick is to use the Grouping tool
Click on the grouping tool.
Hit the "New Group" button.
Call it "lamp" or something.
Hit the "Add Materials" button, then select the material zone that belongs to the lamp.
At this point your new group will consist of everything with that material zone.
Hit the "Create Prop" button. (Not the "Spawn PropS" button!)
Close the Grouping dialog.
8. Now your Lamp should be a separate prop. You should be able to select it and
move it like any other prop.
9. You can then delete the original scene.
LaurieA posted Fri, 14 December 2012 at 7:34 AM
you could select the lamp with the grouping tool and spawn a prop from it then make the materials on the original transparent.
lesbentley posted Fri, 14 December 2012 at 1:50 PM
Quote - each piece of the moel has it's own material group, so much so that I can make all the other bits of the model invisible within the material room, but find that the invisibilised bits are casting weird artefacts.
Make sure that the Specular_Value is zero (or that the Specular_Color is absolute black), and that the Transparency_Falloff is set to zero. Failure to do both of those things are common causes of incomplete transparency.
lesbentley posted Fri, 14 December 2012 at 2:15 PM
Ockham has given an excellent explanation of how to separate part of the object. At the risk of complicating a simple explanation, I would like to add a suggestion.
Before you do step #7, you can reselect the original prop, then do 'Invert' in the Grouping Tool, then click the "Create Prop" button again. This will give you a prop that contains everything except the previous group (lamp). You can now delete the original prop from the scene. You should now be left with two new props, the lamp in one, and everything but the lamp in the other.
Paul Francis posted Fri, 14 December 2012 at 3:08 PM
Guys - thanks so much for these suggestions - I'll give them all a try!
My
Asus P5Q
Pro MB, Quad
man really
yet.....!
My
markschum posted Fri, 14 December 2012 at 5:53 PM
and save themback to the props library if you want to keep them for another scene.
