Forum: Vue
Subject: Installing Vue 11 Infinite on Windows 8
Mari-Anne opened this issue on Jan 04, 2013 ยท 4 posts
Mari-Anne posted Fri, 04 January 2013 at 4:25 PM
Does anyone know if it is necessary to be in Compatibility Mode to install Vue 11 Infinite on a Windows 8 (64-bit) computer? And what about other programs that run on Win 7 and earlier versions of Windows, such as 32-bit programs?
Peggy_Walters posted Sat, 05 January 2013 at 10:33 AM
From the registered user forum:
Vue 11 hasn't been completely updated for Windows 8 as yet. So after you've installed your new Vue 11 Artist product, right-click on the program icon and select Properties. On the Properties dialog, select the Compatibility tab.
Set the first option, which is Compatibility mode, to run this program in compatibility mode for Windows 7. Vue should run just fine with that setting.
Cheers, Lee
LVS - Where Learning is Fun!
volter posted Sun, 06 January 2013 at 7:23 PM
I am using Vue xStream with Windows 8 Pro (64 bit)
Just install and run as any other applicaiton with out any tricks or special settings. Run smooth with out any problems.
Mari-Anne posted Mon, 07 January 2013 at 12:36 PM
OK, thanks to both of you!
