Darboshanski opened this issue on May 03, 2001 ยท 4 posts
Darboshanski posted Thu, 03 May 2001 at 9:15 AM
wulfie66 posted Thu, 03 May 2001 at 9:54 AM
not bad...but I think his forehead is WAY too big!!!
tbsro posted Thu, 03 May 2001 at 3:17 PM
Honestly, it's pretty good for a first attempt, but the scar does not look real at all. Looks more like a stain. The scar should be more the color of his skin, but paler, and not all one color, it should have some highlights and darker areas, too, without getting out of the tone of the skin around it. Maybe a bit pinkish. The facial hair is much too sparse, and in my opinion should be darker, and should not be all one color. You need to mix in some darker and lighter hairs for a more realistic looks. Same thing with the heir. It should have some darker areas and some lighter areas. And the airbrush spots are visible at the hairline. The hairline should be lines blended into the scalp and forehead area, not spots. Just some helpful hints, not meant to be degrading. I think it's a very good first attempt. :) Tara
arabinowitz posted Fri, 04 May 2001 at 11:07 AM
It's not that the forhead is too big. CHange your camera focal size to about 75-80 on the face camera. Right now it is almost wide angle (probably set to defaust 38) and it makes the center of the image bulge out. Select your camera and pick the first dial "Focal" and change the number. Then rerender - you will see a major difference. Aharon
