Thaarhac opened this issue on Jan 14, 2013 · 6 posts
Thaarhac posted Mon, 14 January 2013 at 1:46 AM
Nothing I have in Poser 6 works in Poser 9. I have been adding content to Poser 6 for years and bought Poser 9 recently. I am NOT very PC savy when it comes to finding a way to get poser 6 stuff to work in Poser 9. I'm not sure if this is even possible. Thanx ahead of time for any help I can get.
Teyon posted Mon, 14 January 2013 at 1:55 AM
How are you trying to get the stuff to work in Poser 9 exactly? The suggested method is to link the Runtime of Poser 6 from within Poser 9's library. If you are doing any copying and pasting then you've made a mistake. So, can you clarify your method so we can all help you a bit better?
Teyon posted Mon, 14 January 2013 at 2:01 AM
Attached Link: Installing Poser Content From A Previous Version Of Poser
Here's our Knowledgebase article on the subject.
(see attached link)
Thaarhac posted Mon, 14 January 2013 at 2:44 AM
Hey Teyon,
You are correct in assuming I was going the cut and paste route. AND you were also correct in assuming that that method did NOT work.
I will go to the link you sugested and see if the advise it gives works...thanks for your quick response. I will let you know how it works out. Wish me luck...
Thaarhac
Thaarhac posted Mon, 14 January 2013 at 3:30 AM
It worked! Runtime Loaded and seems to have no issues - as of yet. For me, it is always something simple that baffles and evades my limited mind. Thanx Teyon for your help...My Poser 9 program is no longer a digital paperweight
hborre posted Mon, 14 January 2013 at 8:42 AM
Although content may do well on a copy and paste, python script will get broken between different versions. Linking is your best alternative.
