Subject: IK question
Winterclaw opened this issue on Jan 14, 2013 ยท 5 posts
Winterclaw posted Mon, 14 January 2013 at 8:05 AM
Is it possible to turn IK off by default so I don't have to turn it off all the time?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
geep posted Mon, 14 January 2013 at 8:21 AM
Edit the cr2 file? 😄
cheers,
dr geep ... :o]
edited 10/5/2019
hborre posted Mon, 14 January 2013 at 8:30 AM Online Now!
IIRC, you might be able to save back into the Library with IK off in the latest versions of Poser.
PhilC posted Mon, 14 January 2013 at 8:57 AM
You need to name the leg IK chains anything but the default names.
Poser 4 nude female:-
Internal names: "rightLeg", "leftLeg"
External names: "Right Leg", "Left Leg"
These appear to get turned on by default even if you save with them turned off.
Renaming to something like "right-leg", "left-leg" fixes it.
brewgirlca posted Mon, 14 January 2013 at 10:31 AM
The easiest solution is to create your own base V4 and save her in your figures library. I took a v4, turned off her IK chains, loaded her ++ morphs and then saved her in my figures library under "V4 base". I use this as the starting pointfor all my new projects. I have this for Aiko and M4 too. Saves a lot of start up time.
