Fenric opened this issue on Jan 15, 2013 · 11 posts
Fenric posted Tue, 15 January 2013 at 12:15 PM
http://fenric.com/wordpress/store/
I've got 5 useful new plugins for you to try. Everything is try-before-you-buy, so there's no risk!
Supporting Carrara 7 and 8, Mac and Windows, 64 bit where available (except for Windows XP)
GKDantas posted Tue, 15 January 2013 at 1:19 PM
3doutlaw posted Tue, 15 January 2013 at 1:22 PM
Fenric, where do I find the command for the Shader Doctor...or did it just work already when I opened a PZ3, and I was not aware of it? The Readme sort of implies that, but then it also says "all selected items"
...or I just completely misread it, which is the most likely problem ;-)
I wanted to try it out.
3doutlaw posted Tue, 15 January 2013 at 1:26 PM
Oh, I found it, under Edit Menu, 3rd from bottom.
Fenric posted Tue, 15 January 2013 at 2:51 PM
It's hard to give exact guidance other than "In the Edit Menu". Generally, under the "Fenric" sub-menu, but if you only have one then it won't be.
My "Fenric" sub-menu is very nearly as long as the main Edit menu itself. :)
animajikgraphics posted Tue, 15 January 2013 at 3:19 PM
3doutlaw posted Tue, 15 January 2013 at 3:41 PM
Quote - It's hard to give exact guidance other than "In the Edit Menu".
True, but nothing actually says it is "In the Edit Menu" in the download ;-) Worked good! I'll be buying it.
Fenric posted Tue, 15 January 2013 at 7:25 PM
Yeah, sorry... As a developer, I'm too used to knowing that the Edit menu is the only place the commands will go.
I'll put some tips up on the download page to make it clearer.
booksbydavid posted Sun, 20 January 2013 at 8:46 PM
Grabbed a couple already. Very useful stuff. Will probably go back for more soon.
Thanks, Fenric! Keep'em coming. :)
headwax. posted Wed, 23 January 2013 at 7:46 PM
yes thanks Fenric - you are worth your weight in expensive metal :)
xiayu posted Wed, 23 January 2013 at 9:10 PM
Attached Link: Chinese translation to English
ah,it sounds good, useful for me
