gendragon opened this issue on Jan 24, 2013 · 11 posts
gendragon posted Thu, 24 January 2013 at 3:21 PM
Temple of Gedaya - Medieval Architecture, based on a history that I wrote 8 years ago.
A story that happens in a distant planet of the Earth. The model was modeled in CInema4D, is in the format wavefront obj, model UVmapp and vob format for Vue Infinite 6.
I built the internal atmosphere of the model. If you hide the wide windows and door, it can visualize the floor and a stairway that will give access to the second floor.
I was the whole careful so that the model was not heavy, then I built with possible minimum of polygons. Now it is with 8.668.
The model possesses two textures in the resolution 2000 x 2000 pixels that maps the whole model. The Windows and doors share with the textures, but it doesn't commit.
I model definitively in the case of you to want to eliminate them.
gendragon posted Thu, 24 January 2013 at 3:22 PM
gendragon posted Thu, 24 January 2013 at 3:23 PM
gendragon posted Thu, 24 January 2013 at 3:24 PM
gendragon posted Thu, 24 January 2013 at 3:26 PM
gendragon posted Thu, 24 January 2013 at 3:27 PM
gendragon posted Thu, 24 January 2013 at 3:30 PM
LaurieA posted Thu, 24 January 2013 at 3:31 PM
Great interiors too btw ;). I like your stuff...shows a lot of imagination :).
Jumpstartme2 posted Fri, 25 January 2013 at 2:15 AM
~Jani
Renderosity Community Admin
gendragon posted Fri, 25 January 2013 at 6:48 AM
Thanks for all comments! Look for my new item here:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2862780
Anderson :biggrin:
3eighty posted Fri, 25 January 2013 at 3:09 PM
Anderson> Just a quick Thank you for all your work and generosity.....
3eighty
Richard
