Subject: Walk Designer ?
Darkworld opened this issue on Feb 07, 2013 · 2 posts
Darkworld posted Thu, 07 February 2013 at 2:36 PM
So my Walk Designer is suddenly broken... using PPro 2012, it used to work fine now it says Ryan_WD is missing, no clue what that is or where to find it.
Any tips?
lesbentley posted Thu, 07 February 2013 at 5:18 PM
It's a cr2. Look under the path you installed the content to when you first installed Poser. It should be in this path:
[YourMainContentFolder]RuntimeLibrariesCharacterWalkDesignerRyan_WD.cr2
E.g:
My DocumentsPoser Pro 2012 ContentRuntimeLibrariesCharacterWalkDesignerRyan_WD.cr2
If it's not there you may have accedentally moved or deleted it. If it's not there, do a Search of you your HDD for  "Ryan_WD.cr2", and move it to the correct location. If it is not found on your HDD, do an over the top re-install of Poser to the same path that you installed to originally.
