somebody321 opened this issue on Feb 23, 2013 ยท 7 posts
somebody321 posted Sat, 23 February 2013 at 3:22 AM
Hello, i would like to know if it is possible to detach part of poser model and make it a separate prop, for example if i had a whole mellon and i wanted to make 2 halves of the same mellon(note mellon is only one part) can i do it, i am aware that my new prop would be hollow inside and that i would have to add inside part on my own.
ghostman posted Sat, 23 February 2013 at 6:11 AM
You can use the grouping tool for that. Select the polys you want and then spawn a new prop.
"Dream like you'll live forever. Live like you'll die tomorrow."
somebody321 posted Sat, 23 February 2013 at 7:21 AM
As i said i am quite a noob, please give it like- open menue "this" select tool"this" and then do "this" thank you.
vilters posted Sat, 23 February 2013 at 7:30 AM
Step by steps are in the manual: Group editor.
Or look for Dr Geeps tutorials on the group editor.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
somebody321 posted Sat, 23 February 2013 at 7:58 AM
Tnx
lesbentley posted Sun, 24 February 2013 at 1:42 PM
Select the thing that you want to split. From the Editing Tools palette, click on the Grouping Tool icon. Click the 'New Group' button, and give the group a descriptive name (eg "Half_Mellon"). Don't use any spaces in the name, but you can use an underscore or hyphen to separate words.
The new group should now be the active group, and you should see its name in the Group Editor, if not, click on the down arrow and select it from the list.
Now you need to select the polygons to be included in your new prop. Use the cursor to draw a rectangle around polygons that you want included in your prop, or click on a polygon to select it individually. Selected polygons will turn red. You will usually need to use the Track Ball in the Camera Controls to rotate the camera around the model so that you can select polygons on different sides.
If you select some polygons by mistake, holding down the keyboard Ctrl key whilst drawing a rectangle around them will deselect them.
Sometimes in the process of selecting polygons, a camera or other item may inadvertently become the selected item. If that happens, you will need to reselect the model and the group that you are working on.
Once you have the required polygons selected, click the 'Create Prop' button, and give the prop a name. This will create a new prop from the selected group. You may not be able to see the new prop, as it will overlay the original model, you can hide the original, or move it out of the way, so that you can see the new prop. Now you can either save the new prop to the Props library palette, or export the prop as an obj file.
To save it to the library: Open the Library (Shift+Ctrl+B), select a Props library, click the large "+" sign near the bottom of the palette, and type in a name for the prop.
To export it as an obj file: From the menu bar File menu select Export > Wavefront OBJ. Click 'OK' in the 'Export Range' window. Click in the 'UNIVERSE' box of the 'Select Object' window to clear all selections, then click in the box next to your prop to select it, then click 'OK'. In the 'Export Options' window, select only the 'Include existing groups...' option, leave the other options blank.
Kazam561 posted Tue, 26 February 2013 at 1:04 AM
Thank you Les :)
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
