annie_dubreuil opened this issue on Mar 04, 2013 · 15 posts
annie_dubreuil posted Mon, 04 March 2013 at 10:45 AM
Hello members,
I am a new user of Poser and new to the 3D art world. I would like to know if I can convert a jpeg file to a Poser file. Is this possible?
Thanks!
PhilC posted Mon, 04 March 2013 at 11:00 AM
If you are asking if you can use a jpeg as a texture image within Poser then the answer is yes you can, no conversion required.
If however you have a picture of a figure/character/object and want to see that as a 3D model you will need to first create it (probably from scratch) in a 3D modeling application.
Generally Poser is used to manipulate and animate 3D models rather than create them.
Would you be able to post a copy of the jpeg to this thread? That way folks may be able to help you better.
annie_dubreuil posted Mon, 04 March 2013 at 2:06 PM
Ok, I see. Thanks.
I've been doing some research and it seems that there are softwares that help you transpose pictures into 3D objects. Do you know which are the most user friendly / efficient?
airflamesred posted Mon, 04 March 2013 at 3:03 PM
Once again, you will need to explain what you want to do, then people will know how to help you.
annie_dubreuil posted Mon, 04 March 2013 at 9:48 PM
I have a picture of a dog and I would like to create a character with it. Maybe it would be simpler to use an existing model and modify it. Is that feasable?
PhilC posted Mon, 04 March 2013 at 10:14 PM
You pays your money, you takes your choice :)
annie_dubreuil posted Wed, 06 March 2013 at 5:28 AM
Thanks!
And can I import this in Poser and modify it?
airflamesred posted Wed, 06 March 2013 at 6:36 AM
Attached Link: poser dog mophs
Import what?try this
annie_dubreuil posted Wed, 06 March 2013 at 2:52 PM
Thanks for the link.
I see that I'm not very clear... perhaps because I know nothing about this stuff! (by the way, can you tell me if there is a good tutorial somewhere?)
Question: In Poser, there are models in the library. Seems that these models (example: Alyson hair) are not modifiable. You can put it on the frame, put you cannot change its structure. Am I right?
Question: If I take a 3D picture (with 3Dsome, let's say), would I be able to import it in Poser and then modify it?
Thanks a lot for your help!
airflamesred posted Wed, 06 March 2013 at 6:41 PM
The poser question - long time since I used it, and couldn't really tell you. Try the poser forum.
The 3dsom - My guess it will cost money. As I understand it you send them a picture and they send you back a mesh to import into poser (possibly)
annie_dubreuil posted Wed, 06 March 2013 at 8:32 PM
thanks for the info!
jestmart posted Wed, 06 March 2013 at 9:31 PM
The models created from these 2D to 3D programs are crap. They may work for a static prop but not for a posable figure. The topology is a mess that would bend in horrible ways. Either find an exceptable Poser figure or learn to model, UV map, texture and rig.
annie_dubreuil posted Thu, 07 March 2013 at 8:37 PM
Thanks. I guess I am going to start learning seriously how to model in Poser.
airflamesred posted Fri, 08 March 2013 at 6:45 AM
Well I, for one, will look forward to your poser modelling.
VolcanicMink posted Sat, 09 March 2013 at 5:43 PM
There are some helpful tutorials on YouTube for Poser. I've been floundering with Poser also. I like the program, but finding useful info for it isn't easy. If you can, pick up the tutorial on Renderosity by fugazi1968 called 'Poser from Beginner to Advanced'. It's expensive, but it's on sale right now until March 15. It's easy to follow and covers everything well.
fugazi1969 also has great tuts for Silo 2.4 if you're looking for a good modelling program. Silo is not free, but it's lower on the price scale, and one of the most "user-friendly" in my opinion. YouTube has some good base-level tuts for this program as well. I can finally say that I'm enjoying modeling now with this program, and it works well with Poser.
