strongbear opened this issue on Mar 14, 2013 · 14 posts
strongbear posted Thu, 14 March 2013 at 7:24 AM
What would be the best figure to use for a Poser two-year-old boy? I think the Matt figure looks slightly older (about 5 or more) and the next one down from that is the Millennium baby who is obviously too young.
Are there any other kids around, or are there any morphs for Matt to make him look younger still?
false1 posted Thu, 14 March 2013 at 7:53 AM
There's the Toddler from Daz and Baby 4 on ShareCG.com. Both require Kids 4 and morphs. Baby 4 can be scaled up to look older since it starts from the K4 base.
________________________________
hborre posted Thu, 14 March 2013 at 8:32 AM
The K4 toddler, when released, only worked with DAZStudio and not worked correctly with that Poser version at the time. However, if you have P9/PP2012, the scaling problem has been corrected and the feature now usable.
pitklad posted Thu, 14 March 2013 at 8:50 AM
strongbear posted Thu, 14 March 2013 at 8:55 AM
Thanks. I'll give it a try.
randym77 posted Thu, 14 March 2013 at 12:28 PM
Quote - The K4 toddler, when released, only worked with DAZStudio and not worked correctly with that Poser version at the time. However, if you have P9/PP2012, the scaling problem has been corrected and the feature now usable.
Interesting. I didn't buy it when it first came out because it was DS or Carrara only. It still says that in the description. But the box on the bottom lists Poser as compatible software. I wasn't sure if it was with DSON or what.
hborre posted Thu, 14 March 2013 at 12:38 PM
The initial problem was scaling. Poser could not properly scale the toddler morph to K4. But someone else has posted that scaling now works well with P9/PP2012 and reported that the K4 Toddler is now possible. I do have that package when it was offered free. Time to test drive it.
ashley9803 posted Fri, 15 March 2013 at 12:59 AM
danidh posted Fri, 15 March 2013 at 2:44 AM
The scaling issue with the toddler's arms is easily fixed by selecting the shoulders (left and right) and rescaling the Scale (xyz) slider to 86% (top number). Dani
ashley9803 posted Fri, 15 March 2013 at 3:14 AM
Quote - The scaling issue with the toddler's arms is easily fixed by selecting the shoulders (left and right) and rescaling the Scale (xyz) slider to 86% (top number). Dani
Absolutely, and if you use the 'show dials' python script you can further refine scaling with individual x, y or z scalers for the shoulders and collars.
false1 posted Fri, 15 March 2013 at 12:42 PM
Actually I was having a problem with the back of the toddlers head. It still appears to be there in 2012. There is a ridge where the neck joins the head. It's kinda scary looking. Don't have a picture though. Have you turned the baby around?
danidh posted Fri, 15 March 2013 at 2:19 PM
false1 posted Fri, 15 March 2013 at 8:50 PM
Quote - No problem here. Just rendered an image and the baby's head is fine in the back.
Must just be me. I'll try reinstalling over a fresh K4 or maybe I should apply Morphs++ before the Toddler. BTW, where'd you get the hair, is it part of the texture?
danidh posted Sat, 16 March 2013 at 4:05 AM
That's the texture. It's Jackie by Mech4D bought @DAZ.
