Javil opened this issue on Mar 15, 2013 · 6 posts
Javil posted Fri, 15 March 2013 at 1:58 PM
Hello all,
I like to know how I manage to create 2 colors and different altitudes in the function editor. (Vue Inf 7.x)
I tried al lot, but I cannot find the solution.
The lower areas need to be for example green and the higher areas need to be red.
Any idea which functions I need to combine?
Would be great to see how that works!
Thx
more VUE Infinite on -> javildesign.com
thd777 posted Fri, 15 March 2013 at 3:34 PM
Ciao
TD
Javil posted Sat, 16 March 2013 at 2:52 AM
Hi thd777,
no, not like that.
I want the area close to the 'core' of the sphere to be green, and the 'higher' altitudes to be red. You know what I mean now?
Thanks!
thd777 posted Sat, 16 March 2013 at 6:41 AM
TD
Javil posted Sun, 17 March 2013 at 7:32 AM
Hi thd777,
Thank you.
I did not notice your attached image file. Did you edit the reply afterwards?
Eventually I noticed an example in Vue that I needed. Like in your example.
Attach the colormap to the fractal that is connected to the position and bumpmap.
I think from vue 8 they changed the FE, because the displacement tab in the FE is called bump or it doesn't exist in FE. (or I'm confused O_o).
My result:
thd777 posted Sun, 17 March 2013 at 10:31 AM
Looking good. Glad you you figured it out.
Yes, I forgot to attach the image when I posted and had to edit the post. I guess you looked while I was editing.
Ciao
TD
