Subject: DSON iMPORTER for POSER
Steeleyes101 opened this issue on Mar 19, 2013 · 9 posts
Steeleyes101 posted Tue, 19 March 2013 at 8:46 PM
Please can someone help me with DSON iMPORTER for POSER   I have it installed ok and am trying to import the following into poser
I have installed it into DAZ Studios and also installed DSON iMPORTER for POSER into Poser and DAZ S, but when ever I try to use I get the following error msg.   Can someone tell me what Im doing wrong pleaseeeeeee.
Thanks much
Steel
nobodyinparticular posted Tue, 19 March 2013 at 8:57 PM
Have you installed the Genesis Starter Essentials?
Steeleyes101 posted Tue, 19 March 2013 at 9:12 PM
Yes nobodyinparticular  I have installed the starter kit too
hborre posted Tue, 19 March 2013 at 9:35 PM
But where are they installed?  That warning is essentially telling you that your installation went into Win7's Program Files folder which is protected by UAC.  I installed mine into the Documents folder and have no such writing problems.
Steeleyes101 posted Tue, 19 March 2013 at 10:08 PM
Ok so you are saying I should uninstall and reinstall in to the documents folder?????
Or are you talking bout the path when you click on scrips  DSON IMPORTER PREFERENCES?
If youre talking bout the Preferences its going to MyDocuments/ DAZ 3D/ Studios/ My Library
hborre posted Tue, 19 March 2013 at 10:53 PM
Is this your initial installation which is giving you the warning?
Steeleyes101 posted Tue, 19 March 2013 at 11:01 PM
Not sure what you mean,  but I have installed it into Poser and everything works up to the point where I try to import the set over from daz to poser.   When I click on the item I want to use which is in my poser props folder thats when I get the error msg
LaurieA posted Wed, 20 March 2013 at 5:18 AM
The DSON program...the thing that runs...gets installed to your Poser program directory. Everything else - the content from the starter kit, etc. gets installed to your Poser content directory. I installed mine in a separate DSON folder. No problems (other than DSON's general sloth-like speed in Poser. :).
Steeleyes101 posted Thu, 21 March 2013 at 6:57 PM
Ok guys I found the problem   In poser you have to add a direct link to the My Library folder in your documents folder that DAZ Studios automaticly makes when you install it.
Once you have done that youre good to go
Thanks for all your help
Steel
