PrecisionXXX opened this issue on Mar 28, 2013 · 10 posts
PrecisionXXX posted Thu, 28 March 2013 at 8:08 PM
Clickie for bigger.
Doric
The "I" in Doric is Silent.
LaurieA posted Thu, 28 March 2013 at 8:21 PM
I think the scale of your bricks are somewhat tiny for as small as the house looks ;) I'm looking at the door and it seems those bricks wouldn't be as big as the doorknob.
PoppaC posted Thu, 28 March 2013 at 8:47 PM
looking great to me will love to be able to use it just make each section like roof walls so they can be hidden for better camers placeings and rendering. Brick look good as well i have no problems with the size
PrecisionXXX posted Thu, 28 March 2013 at 9:24 PM
Brick size is no problem, a matter of changing a number in the material room. Proportions of the bricks may be a different matter, the texture generated in PovRay, and I think the proportions may be the standard for another country. I may be able to change the mortar width and thickness, before I give up, I'll give it a try.
Povray gives control over almost everything, all I have to do is figure out the ratio and plug that in, it can make anything from bathroom tiles to cinder blocks, or even ancient stone blocks. Pretty math intensive and I don't have a lot of math.
It's not that small though, the foundation is 26 by 16 feet, about the same width as my house. Just not very deep, the main room is 16 by ten (?) I think. Outside dimensions given. And I'm still working on the "I don't like this".
Doric.
PrecisionXXX posted Mon, 01 April 2013 at 3:16 PM
Doric
PrecisionXXX posted Tue, 02 April 2013 at 11:58 PM
Hmm. Minor problems,due to not thinking ahead while constructing. I'm going to try to fix one more glaring error, but it's not going to come out as I had hoped. The glaring error can be seen on the right hand side of the roof, well, I fixed that and replaced it with an "I like this even less!" A mistake in construction, or sometime after is going to prevent assembling walls that can be hidden, a definite disadvantage, I'm aware of that. But, sometime tomorrow I'll do the last "fixing" (screwing up royally) and try to get it on sharecg before too late.
I'm starting to like the white trim, but for anything else, a trip to the material room will change it easily enough.
Doric.
PrecisionXXX posted Wed, 03 April 2013 at 1:13 AM
Attached Link: http://www.sharecg.com/v/68448/view/11/Poser/Small-Brick-cottage#
It's up at Sharecg now. Enjoy, maybe.Doric
Tessalynne posted Wed, 03 April 2013 at 4:40 AM
Thank you for sharing this.
amileduan posted Sat, 06 April 2013 at 11:07 PM
Don't very like a 3D model,lack of some feeling of stereo.
render farm :Intel Xeon E5560 * 2, 16 cores with hyper-threading,Win7 64bit.
PrecisionXXX posted Sun, 07 April 2013 at 12:00 AM
Quote - Don't very like a 3D model,lack of some feeling of stereo.
I think you're saying you don't like it, however, it wasn't rendered to be a work of art. It was rendered to say, "Here be a model. This be what it looks like. If you like it, fine, if not, that's fine too."
Like most of my models, created because I had a need for something close to what it looks like. No other reason, Period.
Doric.
