Forum: Carrara
Subject: Need help with Deeper plug-in
fuzzoom opened this issue on Apr 01, 2013 · 4 posts
fuzzoom posted Mon, 01 April 2013 at 9:17 AM
I got Inagoni plug-in Deeper for Carrara 7.2 Pro.  I cannot get Deeper to work at all.  The instructions on the Inagoni page for using Deeper don't work.  I put a jpeg image in the Color sub-shader and a normal map into the bump map sub-shader under the Deeper shader.  The texture from the normal map doesn't display at all.  I don't know if I have set up the shader correctly.
MarkBremmer posted Mon, 01 April 2013 at 11:01 AM
The normal map goes in the sub shader. The image shows how it's done.
GKDantas posted Mon, 01 April 2013 at 11:36 AM
Thats it! And you can increase the depth in the Bump Amplitude box.
Follow me at euQfiz Digital
fuzzoom posted Mon, 01 April 2013 at 3:45 PM
Thank you!  :-)
