Subject: StudioArtVartanian Atlas render issues.
sdmakai73 opened this issue on Apr 11, 2013 ยท 9 posts
sdmakai73 posted Thu, 11 April 2013 at 12:37 PM
My GF got me Atals as a gift due to a slight resemblance and I had no issues using it in Poser 8. Got Poser pro 2012 for X-mas and started transfering all my 8 runtime to 2012.
Loaded Atlas and did a render it he looks like he recently had a face lift. He still renders fine in 8 but 2012...well, he is no slowly making his way to the unused files.
All renders I've done to compare are identical and the results are the same between the two.
including samples
Is there something I'm missing here or is there an issue between to 2 version of poser in how they handle maps?
Again...all setting are identical between both versions and Im puzzled.
sdmakai73 posted Thu, 11 April 2013 at 12:38 PM
This is default firefly in poser 8
This is advanced render settings in poser 8
sdmakai73 posted Thu, 11 April 2013 at 12:39 PM
Poser Pro 2012 default firefly
sdmakai73 posted Thu, 11 April 2013 at 12:40 PM
Poser Pro 2012 advanced render settings
JimTS posted Thu, 11 April 2013 at 12:50 PM
Yes the render engine/Lights/texture/node reltationships have changed and a default render from each version will differ
among other changes the texture filtering has changed
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
hborre posted Thu, 11 April 2013 at 2:21 PM Online Now!
Gamma correction in render settings.
hborre posted Thu, 11 April 2013 at 2:35 PM Online Now!
Also you would need to change the gamma to all transmaps, bumps and displacement maps to a setting of 1.
sdmakai73 posted Thu, 11 April 2013 at 3:21 PM
Worked. Thank you
