Zanzo opened this issue on Apr 14, 2013 · 9 posts
Zanzo posted Sun, 14 April 2013 at 7:19 PM
Anyone know of a script that puts the selected object in front of the active camera?
I hate adding a prop then having to look for it. Do you guys know a clever way to put the item you add directly in front of you?
I'm thinking a script. Before I write it, I was hoping someone else already did it.
LaurieA posted Sun, 14 April 2013 at 7:22 PM
[o] little button at the top of the scene window.
DeathMetalDesk posted Sun, 14 April 2013 at 7:51 PM
Point at selected in hierarchy too convoluted? Although, I must admit that laurie's cryptic response had me looking around for a little undocumented button for a second (and jeez will I be embarrassed if there is one). No keyboard short cut for point at though... unless they added a "Pro" one ;)
Edit_ ahhh, nevermind he wants to put the object in front of the camera rather than have the camera point at the object. Hmmm, that's a good one. An objects origin is at zero xyz when it loads even if those coordinates aren't matching the zero coordinates of the poser work space. I think, stumped on this one.
LaurieA posted Sun, 14 April 2013 at 7:53 PM
It's looks like brackets with a ball in it. LOL
Maybe it is just in pro. I have no idea but I do have pro.
AlanaDale posted Sun, 14 April 2013 at 8:04 PM
the shortcut for "frame selected" is ctrl shift =
it's also on display menu
DeathMetalDesk posted Sun, 14 April 2013 at 8:04 PM
"Edit_ ahhh, nevermind he wants to put the object in front of the camera rather than have the camera point at the object. Hmmm, that's a good one. An objects origin is at zero xyz when it loads even if those coordinates aren't matching the zero coordinates of the poser work space. I think, stumped on this one."
Yeah, it's not the traditional point at anyway... They must have added the little ball with brackets in Pro, Laurie. I'm not seeing it.
_ solved, Poser 9 feature.
Zanzo posted Sun, 14 April 2013 at 8:08 PM
Quote - [o] little button at the top of the scene window.
That moves camera to focus on the selected object. I want the opposite effect. Basically whereever my camera is pointed, I want the prop to end up somewhere in front of the camera.
Instead of moving the camera, it moves the object in front of the camera.
LaurieA posted Sun, 14 April 2013 at 8:11 PM
Quote - > Quote - [o] little button at the top of the scene window.
You're out of luck then. LOL
DeathMetalDesk posted Sun, 14 April 2013 at 8:12 PM
Python script "snap to" by Ockham, moves selected object to clicked location. Not sure if it's Poser 9/pro usable though...
http://ockhamsbungalow.com/Python/
Results are variable.
