Subject: Strange result with Reality-Luxrender
martial opened this issue on Apr 26, 2013 · 9 posts
martial posted Fri, 26 April 2013 at 3:10 PM
Bonjour
This is a part of a scene i have realised this week .Like you see at the left the Reality -Luxrender seems to render a part of the dress as it was transparent (reduced jpg here ) .Look at the right the same scene rendered by Poser standard render settings
No Ibl or Gi lights  here just standard lights Not Reality light also
Someone has explication for this?
Thanks
Pret-a-3D posted Fri, 26 April 2013 at 3:11 PM
Hi.
Have you checked the alpha channel setting for that material?
I mean in the Reality material editor.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+: https://plus.google.com/106625816153304163119
The Reality Gallery: https://reality-plug-in.deviantart.com
LaurieA posted Fri, 26 April 2013 at 3:38 PM
Looks like it simply didn't pick up the transmap on that piece of the dress.
martial posted Fri, 26 April 2013 at 3:49 PM
Thanks
Your are right
I disconnect the alpha (wich works in Poser rendering) from the transparency settings and it seems ok now in Luxrender (still rendering)
Pret-a-3D posted Fri, 26 April 2013 at 3:54 PM
You don't need to disconnect or change the Poser materials, just edit the alpha channel in Reality and you will be able to rende rin both situations.
Cheers.
Paolo
Tw: @preta3d
martial posted Fri, 26 April 2013 at 4:51 PM
ok
but i don't really know what you mean  by edit
I see the picture i must edit (white on black backgound) but what i must do on it ? Inverse it ?
Pret-a-3D posted Fri, 26 April 2013 at 5:03 PM
In the Reality Material Editor you have the list of materials. You click on the material for the dress and then click on the "Alpha Channel" tab. In there there should be a texture for the transparency map and a value for its strength. Is that value at 1.0?
Also, are you using the latest build, which is 3.0.1.193. If not please update and try again.
Hope this helps.
Paolo
Tw: @preta3d
martial posted Fri, 26 April 2013 at 6:06 PM
Thanks
I will try during the week end
I have your last update for reality
I just check my rendering with Luxrender  Seems good ,better than my poser render, but still noisy .I will keep it open all this night and see tomorrow
hornet3d posted Sat, 27 April 2013 at 4:14 AM
Quote - Thanks
The way Luxrender works is very different from Firefly and a couple of the differences is that Luxrender gives you a full picture almost form the start but it is noisy.  Also a render in Luxrender never finishes, unless you set limits, it is finished when you like the result and and stop the render.  The longer the render the less noisy it will become, darker scenes tend to take more time to clean up the noise.
If most of the scene is good but you have a particlar area that is noisy, such as a shadow area you can use the 'refine brush tool' to have Luxrender concentrate on that area a little more.
