arrow1 opened this issue on May 09, 2013 · 15 posts
arrow1 posted Thu, 09 May 2013 at 7:29 PM
Does Blender have a particle System? Cheers
Custom built computer 128 gigs RAM,2 Terrabyte hard drive, NVIDIA RTX 3060 12 Gig, Intel i9, Dual Dell Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terrabyte SSD Hard Drive plus 1 Terrabyte Hard Drive,3rd Computer intel i7,64 gigs ram, Graphics Card NVIDIA GeForce GeForce 1660 Ti 6 Gig,1 Terrabyte Hard Drive, OS Windows 10 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus Lenovo Laptop 64 Bit,12 gigs Ram.Intel i7 chip.Windows 10 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.22, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Cybermonk posted Fri, 10 May 2013 at 12:34 AM
Yup does particles and hair; also physics like fluid, wind,rigid and soft body, etc. It's pretty wicked.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
arrow1 posted Fri, 10 May 2013 at 2:07 AM
Wow! thanks. I am hoping it will do smoke! Cheers
arrow1 posted Fri, 10 May 2013 at 2:41 AM
Just downloaded Blender.Where do I find the particle section? The manual does not say how to find them! Cheers
Touchwood posted Fri, 10 May 2013 at 3:27 AM
After adding a mesh object look in the properties panel for an icon that looks like a tick with a ball on top. This will open up to display all the different simulation types.
For smoke remember that it requires a domain for which a cube appears to work best.
HTH
Touchwood posted Fri, 10 May 2013 at 3:32 AM
For tutorials you can go to blendercookie.com or blenderguru.com. Andrew Price has some decent smoke/particle tutorials (but does tend to waffle on a bit)
arrow1 posted Fri, 10 May 2013 at 4:04 AM
Many thanks. Cheers
RobynsVeil posted Fri, 10 May 2013 at 4:53 AM
Until Cycles has "Volume" fully implemented, you'll find smoke (and clouds, all that) more of a Blender Internal thing. Keep in mind that BI will eventually go the way of the dodo.
heddheld posted Fri, 10 May 2013 at 12:17 PM
there is a "quick smoke" under object/quick fx it will set up the domain etc but you still have the settings to tweak for the effect you want
since I have seen you asking about particles in the poser forum just want to point out whatever you do in blender wont go into poser without a fight
arrow1 posted Fri, 10 May 2013 at 7:51 PM
Many thanks for your replies. I am trying to find the easiest program that I can attach smoke onto the funnels of ships. I have Vue 11 Infinite but I cannot any longer afford the upgrades and maintenance programs. I thought maybe blender could import at least an animated Poser ship as an obj or a 3ds and I could apply smoke there! However the learning curve looks extensive! I will have to stick with Vue 11 Infinite. Cheers
RobynsVeil posted Fri, 10 May 2013 at 8:00 PM
An example of Particle-based hair:
Eyebrows and eyelashes. Rendered in Blender 2.67(Linux) Cycles. Shaders are being developed specifically for hair. Still, pretty amazing even without the shader.
Working on hair itself, now.
arrow1 posted Fri, 10 May 2013 at 8:36 PM
RobynsVeil, Is that a Poser figure imported into blender and then rendered? Cheers
RobynsVeil posted Fri, 10 May 2013 at 9:11 PM
Quote - RobynsVeil, Is that a Poser figure imported into blender and then rendered? Cheers
Yes, it's Antonia ... I'm in process of rigging her for Blender (using Rigify) and creating hair atm using particle hair. I'm not in much of a hurry - time limits exist - so all this is going to take a while.
NanetteTredoux posted Sat, 11 May 2013 at 12:26 AM
That looks marvellous Robyn!
Poser 11 Pro, Windows 10
heddheld posted Sat, 11 May 2013 at 1:10 AM
@Arrow yeah you can do that m8 or you could render your smoke in blender as png then use them on prims in poser or paint the smoke in your paint proggy(there is smoke brushes for free I think)
if you have great search-fu check out bagginsbill on rdna and here, I know he did smoke in poser but was a good few years ago so dunno how hard it would be to find
@RV looking good hun but for me you have overdone the eyebrows a bit maybe reduce number of hairs??
