Forum: Freestuff
Subject: Candle Holders Myst
gendragon opened this issue on May 20, 2013 · 13 posts
gendragon posted Mon, 20 May 2013 at 8:20 PM
Hello to all! Here is my new release new model, Sculpted and textured in Sculptris from Pixologic. Post this Tuesday, May 21. The file has been optimized with displacement map (Normal Map) to create and render a better result faster. I tested in Bryce 7.1 and DAZ Studio Pro 4.6, but the model did not load properly "normal map", tried to reconfigure using the Ultimate Pro Unwrap3D to fix this problem, but the problem persists. If anyone could help me in some sense, would be very happy. As reported above, I work with "Ultimate Unwrap3D Pro" and Sculptris to create my textures, but from what I see, the "mtl", does not work properly. However, this file will be posting so soon. Thank you! Enjoy!
Anderson Soares - Gendragon
more
gendragon posted Tue, 21 May 2013 at 10:49 AM
Well, I got no answer or help!:sad:
Post anyway and hope you enjoy, as this is free to use, commercial or noncommercial.
Gen
Alisa posted Tue, 21 May 2013 at 10:53 AM
Hi :)  It looks wonderful -thank you!  I just saw this and I don't have the skills, unfortunately, to help.  Give it time, though - those who can may not have seen it yet.
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
gendragon posted Tue, 21 May 2013 at 11:35 AM
Thanks! :)
Gen
bobbystahr posted Tue, 21 May 2013 at 11:54 AM
have you tried PoseRay...it's very good with .obj and is a free program.....If you send it to me I could try...post it to Freestuff as I'm the Mod there and can HOLD it till it works if you like
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
gendragon posted Tue, 21 May 2013 at 1:05 PM
Hello bobbystahr! Thank you! I posted on Sharecg with the name of "Pot Culture Santarem" and you can download it through this link below:
http://www.sharecg.com/v/69355/browse/5/3D-Model/Pot-Culture-Santarem
Approximately: 16 MB
Let me know when you are ok! :-)
Thank you again. I'll see Poseray!
Anderson Soares - a.k.a - Gendragon 3D
gendragon posted Tue, 21 May 2013 at 1:11 PM
Hello bobbystahr! Where can I find Poseray for Windows!
My version is Windows 8 (64 Bit) - 6 GB RAM - Processor: Core Duo 2.60 GHz
gendragon posted Tue, 21 May 2013 at 1:39 PM
Hello bobbystahr! Found Poseray! Easy to use, but when I import the model for DAZ Studio Pro 4.6, the displacement map "Normal Map" remains 0%. : (
I had to manually fix the intensity to get results!
bobbystahr posted Tue, 21 May 2013 at 1:45 PM
sorry was out doing errands but I see you found it...I guess add a readme explaining the limitation I guess would be my suggestion...I use Terragen 2.5 and it doesn't import displacements so I'm used to doing them after the import.
I see a sound
gendragon posted Tue, 21 May 2013 at 2:13 PM
Ok! No problem! Thanks!
amileduan posted Tue, 21 May 2013 at 10:02 PM
Nice feeling of an antique,good model!
render farm :Intel Xeon E5560 * 2, 16 cores with hyper-threading,Win7 64bit.
gendragon posted Wed, 22 May 2013 at 2:02 PM
Glad you liked it! I am very happy with it!
Enjoy!
Gen
