JANNEMO opened this issue on May 21, 2013 · 7 posts
JANNEMO posted Tue, 21 May 2013 at 7:30 AM
Hi,
We seems to be a few persons with the same problem, maybe someone here knows how to handle that, you can read the whole story on ipisoft forum :
http://forum.ipisoft.com/viewtopic.php?f=13&t=6712
Thanks in advance for any tip, i've been trying to fix that for hours and didn't find any solutions so you're my last hope haha !
markschum posted Tue, 21 May 2013 at 10:36 AM
In Poser open the keyframe editor and select the BODY and HIP actor. If there are no translations or rotation in either actor there is probably a problem in the Names in the bvh file. A bvh file can be opened in a text editor and the list of body parts should be near the start.
JANNEMO posted Thu, 23 May 2013 at 9:16 AM
Hi,
i tried to open a bvh file but didn't really understood what to do then. I can provide you a bvh file if it can help. My bvh files works well with genesis in daz, so i don't understand what's wrong with my character in poser... It could be a paid job to get me out of that hell because i'm beginning to be desperate by this problem...
So :
I capture a dancer with a kinect sensor in ipisoft mocap software and generate a bvh file.
I then need to use that bvh with m4 skeleton in poser.
Between that, i've tried everything but can't get better result than a character who's not moving in the space. To be clear, i lose the hip translations somewhere at the import in poser. No one has ever tried to do the same thing ?
markschum posted Thu, 23 May 2013 at 10:27 AM
I can have a look at it for you. I sent a pm.
markschum posted Thu, 23 May 2013 at 7:23 PM
not sen an email yet.
JANNEMO posted Mon, 27 May 2013 at 11:48 AM
strange, i sent one to you maybe half an hour after your PM. I have worked on that since and found that my bvh files works great with another character, the classic james skeleton from poser ; I guess now that the character is making trouble and not the import settings.
M3 skeleton (which is more or less the same as M4 skeleton) moves in the space ! Good enough for me :)
much thanks anyway !
markschum posted Mon, 27 May 2013 at 2:44 PM
so James ands M3 both work but M4 does not ?
thats curious.
you could load your bvh file and save it as an animated pose , then load that pose to M4 and see what happens. I seem to remember a few body part names are different in the M4 and V4 figures.
