cedarwolf opened this issue on May 21, 2013 · 4 posts
cedarwolf posted Tue, 21 May 2013 at 12:00 PM
How the heck do you turn off the breasts on Genesis so you can use it as an actual male figure, and, while we're at it, how do you turn off the nipples for a smooth surface?
Thanks.
RHaseltine posted Tue, 21 May 2013 at 2:10 PM
They should be off by default - there was a "warrior woman" or something like that at ShareCG that had the female shape memorised and so caused Genesis to load that way - if that's your issue, zeroing the figure shape should work (right-click on the Parameter pane's tab and select Zero>Zero Figure Shape).
cedarwolf posted Tue, 21 May 2013 at 3:20 PM
Thanks, RH. I'll check that out.
cedarwolf posted Tue, 21 May 2013 at 3:32 PM
Worked like a charm!
