Subject: clothing doesnt conform when figure is posed - poser 2012
dougm1977 opened this issue on May 25, 2013 · 9 posts
dougm1977 posted Sat, 25 May 2013 at 12:13 PM
right its obvoiusly something im doing wrong or not doing but when i add clothes to a figure (V4 in this case) I then hit "conform to" and when i then choose a pose the clothing doesnt seem to want to play nice
particulary noticed on dark rose boots when i hit pose the boots nd feet were no longer together (I had used the morph for dark rose before hand)
it happens wih other stuff any idea what im not doing???
ghostship2 posted Sat, 25 May 2013 at 12:38 PM Online Now!
figure menue...turn off IK on the legs of your main figure
ghostship2 posted Sat, 25 May 2013 at 1:00 PM Online Now!
sorry my last post was kind of cryptic
in the figure menue is "use Inverse Kinematics". try tuning this off for the legs. see if this helps. if not it might be that you are selecting the wrong figure when you pose. you want to have your main figure selected when you pose then all the conformed clothes will move with it.
vitachick posted Sat, 25 May 2013 at 1:29 PM
It works since I have BRC Dark Rose and used it many times....Agree click on each item separatly and conform to V4.
Win10  Poser 2014/Poser 11 Daz3D
dougm1977 posted Sat, 25 May 2013 at 2:35 PM
thanks thats what i have done conformed every item as i add them - maybe try the other option on IK
Teyon posted Sat, 25 May 2013 at 3:23 PM
Go to the body actor of each prop/clothing item and Make sure that these things are checked. Should help.
WandW posted Sat, 25 May 2013 at 3:39 PM
IIRC, the feet of Dark Rose boots aren't rigged; you need to lock V4's feet and toes...
ghostship2 posted Sat, 25 May 2013 at 5:33 PM Online Now!
you could also make them invisible in the Hierarchy editor. you'd have to do the same for the stockings
icprncss2 posted Sun, 26 May 2013 at 8:05 AM
The Dark Rose outfit pre-dates 2012 by a number of years.  P6 or P7 if IIRC.  The common practice for footwear back then was conforming to the figure and then hiding the feet and toes.
