EClark1894 opened this issue on Jun 02, 2013 · 11 posts
EClark1894 posted Sun, 02 June 2013 at 12:36 PM
This is a render I did of some book cover art and she is supposed to be carrying a torch.
There should be a very dark shadow behind him, but there's nothing. I've got the lights casting shadows and everything, but I must be missing something, and strangely enough, Poser's manual does exactly spell out how to create the shadows or trouble shoot the problems.
willyb53 posted Sun, 02 June 2013 at 12:40 PM
how many lights and what type are they?
Bill
People that know everything by definition can not learn anything
EClark1894 posted Sun, 02 June 2013 at 12:56 PM
willyb53 posted Sun, 02 June 2013 at 1:15 PM
I include one I did three years ago as an example of one light.
Bill
ashley9803 posted Mon, 03 June 2013 at 1:05 AM
"it seems like the lights are wipeing out the shadows."
I totally agree with that. Also note that if your camera is pointed from where the (single) light is coming from, the shadows can get hidden behind the figure/s. When I use a single light (in IDL scenes eg) I make sure the light is off to one side or the scene looks poorly lit.
piccolo_909 posted Mon, 03 June 2013 at 6:26 AM
When you have multiple lights, they tend to wash out the shadows of each other, especially at high intensities. Start with one light as your main light and go from there. Lower the intensities of your other lights until you get the shadows that you want.
EClark1894 posted Mon, 03 June 2013 at 10:15 AM
Hmm, now that you guys mentiontion it, I think I do see a shadown on the wall behind the girl. It's rather washed out, but I'm sure it's there.
Haven't had a chance to test the theory though. I got a bit side tracked.
moogal posted Mon, 03 June 2013 at 8:40 PM
Also, if you are putting your lightsource inside an object, make sure that object isn't itself casting shadows, otherwise the light won't make it out of the prop.
EClark1894 posted Tue, 11 June 2013 at 8:22 AM
hborre posted Tue, 11 June 2013 at 8:49 AM
Check the material settings for the props in the scene. Anything will an active ambient channel will cause problems with shadows. We may need screencaps of the material room for better diagnosis.
If IDL is being used, check if the prop is a light emitter on the Parameter/Properties Panel.
millighost posted Tue, 11 June 2013 at 8:57 AM
Did you enable shadows in the render settings?
