Sheedee opened this issue on Jun 05, 2013 · 8 posts
Sheedee posted Wed, 05 June 2013 at 9:27 AM
Hello;
Question:
Can EZSkin 2 also be used in PoserPro 2012?...
It says that its only for Poser 9 SR2.1+
And…if it is not for PoserPro 2012…is there a work around, so that it will work in the latest Poser versions?...
Thanks for viewing.
Nyghtfall posted Wed, 05 June 2013 at 9:41 AM
The + sign at the end of the product requirement means Poser 9 SR2.1 and above, so, yes, it also works with PP2012.
LaurieA posted Wed, 05 June 2013 at 9:50 AM
Works fine for me - PoserPro 2012 here. Knock yourself out ;).
hborre posted Wed, 05 June 2013 at 2:05 PM
Yep, works very well in PP2012 latest SR.
Sheedee posted Wed, 05 June 2013 at 5:48 PM
sadly enaugh it seems that my Poser version wont allow me to play with EZSkin...
Nyghtfall posted Wed, 05 June 2013 at 6:17 PM
EZSkin is telling you you're using SR1.6. You need to upgrade to SR3.1.
Eric Walters posted Wed, 05 June 2013 at 11:27 PM
BTW: it works well with PoserPro2014 as well
LaurieA posted Thu, 06 June 2013 at 5:02 AM
Yep, you need at least P9/PP12 SR 3.1 to play...
You should always apply all the Poser updates anyway since they fix bugs and things...
