Lenny2 opened this issue on Jun 07, 2013 · 5 posts
Lenny2 posted Fri, 07 June 2013 at 10:54 AM
Ok, I've had this problem in Poser pro 2012 and now in the new 2014. When I convert clothing for Genesis and then conform it, the figure randomly jumps back and forth between the default state and the morphed one. I've tried crosstalk fixer and the talkback script, but they don't help. I think it's something simple, just not sure what. Any suggestions would be apreciated.
cedarwolf posted Fri, 07 June 2013 at 11:08 AM
Interesting. It'll be quite interesting to find out what the cause and cure is.
Lenny2 posted Fri, 07 June 2013 at 11:41 AM
It also does this with V3 after fitting clothes with the fitting room. So it must be in Poser itself I'm thinking.
ghostship2 posted Fri, 07 June 2013 at 5:15 PM
maybe make sure that it has a different name than the original?
mackis3D posted Sat, 08 June 2013 at 12:40 AM
I also have the problem Lenny2 describes. It has nothing to do with different names because I've tried that already. But I'm wondering whether something about my computer is not up to what it needs. Because if I load something into the Pose scene the camera view is reduced to a view that has its sides cut (that happened also with PP2010 and PP2012). If I click on something in the scene the camera view is again in full mode. And this happens too when I do anything with a Genesis figure in the scene, pose it with a preset pose or conform clothing to it. But the figure is back in the wished position after some lagging seconds.
